Help
Old Aug 12, 2013 | 03:50 PM
norman.hamilton's Avatar
MBenz C205 250d
Help
Bought new wheels 8.5/19 all round and fitted 255/35 tyres but guess what front ones rub against sups strut so no good so id like to pick the brains of anyone who has the above size wheel fitted to the front of their c204 and what size tyre they used, i want to avoid the 'balloon' effect of a small width tyre which looks as though the rim to too wide for it and leaves the edge of the rim exposed yuk so help is needed asap
Norman
Old Aug 12, 2013 | 07:29 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Norman
Perhaps wheel spacers? Just a thought
Old Aug 12, 2013 | 10:38 PM
AV1's Avatar
AV1
C204 C250-CDI
Norman
255 wide tyres up front is definitely too big for this vehicle to begin with.
What are the offsets of the rims ?? I'm guessing they're close OEM or even a higher ET number compared to OEM which is good for outside face fitment, but that's also why they'd be hitting the suspension on the inside face with such a wide tyre there.
Try dropping down to a 235 tyre or if you have room left on the front face and want a quick fix you may have to use spacers.
Just be aware though as I don't know where your from, but in some Countries wheel spacers are illegal and can cause failure problems to some of the other components associated with the wheel hub/s, hence why they're banned.
Old Aug 13, 2013 | 12:24 AM
MBenz C205 250d
Im running 45 offset and from the UK Andrew c has replied with his stats and I think I'll now of with 235/35 but many thanks for your reply
Old Aug 13, 2013 | 01:24 AM
AV1's Avatar
AV1
C204 C250-CDI
235/35 would be the ideal front tyre size for 19's on this vehicle but in combination with an 8" max. width rim with correct offset.
In your case though with the 8.5" wide rim with 45 ET the 235 will have to do, a 225 would be even better for clearance but will be too narrow for your 8.5" rim and give a stretched tyre fitment.
Hope all goes well with the 235's
Old Aug 13, 2013 | 07:26 AM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
~ i am running a 235/45/19 on the front with a 45mm offset & 8.5 width = no rubbing even lowered (eibach pro-kit). the issue could be due to the incorrect offset or the tire size.
Old Aug 13, 2013 | 11:19 PM
MBenz C205 250d
Thanks guys see new post with pics
