How to remove carpet? (driver's side)
Old Aug 26, 2013 | 01:49 AM
irod's Avatar
2010 Mercedes-Benz C300 Sport
Could anyone post some tips on how to remove the driver's side carpet? I'm trying to access the CAN bus conduits and hubs under it.
The carpet is really solid, it doesn't seem to bend, and when I tried to bend it a little to get it off I damaged/broke the block of thick felt sound-deadening material that's attached to the bottom of it.
I'm afraid if I keep tugging at the carpet and bending it I will leave permanent bend-marks on it, since it's not very flexible at all.
Anyone tried this before?
Old Aug 26, 2013 | 11:08 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Move the driver seat back. Remove the gas pedal (1 nut and 1 connector). Remove the plastic trim piece by the park brake pedal. Pull inner door sill trim. Remove carpet by carefully pulling up and rearward (the carpet is in a moulded shape, be careful not to damage the carpet).
Old Aug 26, 2013 | 10:26 PM
irod's Avatar
That worked! Thanks! I didn't have to remove all of the carpet so I just removed the door sill trim and was able to lift the carpet up to access the CAN conduit by unhooking it from the center console/transmission tunnel. Didn't have to remove the pedal.
Appreciate the help.
