91 octane fuel not available in my area. 93 ok?
Old Dec 4, 2013 | 05:56 PM
elmariachi304's Avatar
1967 250SEL, 1982 380SL, 2000 ML320, 2005 SL500, 2018 GLE350
Hey all
My new C250 coupe owners manual specifies 91 octane fuel. However all of the gas stations over where I am in NY have 87, 89 and 93 octane fuel. I am filling with only 93 but my question is: would my car be performing better with 91 even though I'm using something with a higher rating and not lower?
Old Dec 4, 2013 | 06:01 PM
Dr Matt's Avatar
05 CL65
93 will be fine, 89 not likely to hurt it but may decrease performance and milage as your car is tuned for a MINIMUM of 91.
Old Dec 4, 2013 | 09:49 PM
AV1's Avatar
AV1
C204 C250-CDI
Generally the higher the octane number the better it'll be for any car engine, but you may or may not notice any differences using a higher octane fuel with a stock engine.
If the manufacturer has specified a fuel type, then that will do the job according to the specified engine specs, if you were to run a tune other than stock then you would notice a difference with a higher octane fuel used.
Old Dec 4, 2013 | 11:24 PM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
It is usually a Minimum Octane Rating. Are you using a Top-tier brand fuel (Exxon, Shell, Mobile etc)?
Old Dec 5, 2013 | 05:45 AM
You know, I am usually filling with 93 at a Lukoil station but if the brand makes a difference I will be sure to only use the major ones.
Old Dec 10, 2013 | 11:07 PM
acr2001's Avatar
2012 C300 4Matic
91 is the minimum. I usually notice significantly better performance with 93. Could be in my head, but I don't think so. I assume the engine advances the timing to take advantage of the increased octane.
Old Dec 10, 2013 | 11:08 PM
That's cool. A lot of people have talked about throttle and turbo lag with this car, which I have not yet experienced. Maybe this is why?
