Dash info display question.
Old Jul 17, 2014 | 02:46 PM
BeaverMjr's Avatar
2015 C350 Coupe
I have a 2013 c250 coupe. I picked it up in May 2013.
I sometimes use the dash display to check things like average speed and MPG. I've noticed that when it comes to average MPG, the since reset screen does not show a calculation. I do however get a calculation on the since power on screen.
What do I need to do to get avg MPG on the since reset screen. I have not reset it since I picked up the car so that since reset would be from lease inception. I would like to stay away from resetting the system, if possible.
Mike
Old Jul 17, 2014 | 05:56 PM
_demiglace's Avatar
C204, C117
Are you saying there is nothing displayed at all on the 'reset' screen?
Old Jul 17, 2014 | 09:37 PM
BeaverMjr's Avatar
2015 C350 Coupe
That is not what I am saying. I get calculations for average speed, hours driven and miles traveled, but average mpg is --.- I initially thought that I might have to wait for a certain amount of data to be collected. That's not the case. I have over 12700 miles since reset.
Old Jul 18, 2014 | 10:18 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You should be able to see MPG since start, as well as MPG since reset. Its in the owner's manual on how to access these settings
Old Jul 18, 2014 | 10:43 AM
BeaverMjr's Avatar
2015 C350 Coupe
Thanks Capt_obvious.
Following to the manual, I know how to navigate to the "since reset" screen. The manual does not explain how to get --.- to change to a number for mpg on that screen.
My buddy has a 2014 M class and his shows a value for MPG on the "since reset" screen.
I'm actually stopping by the dealer after work and will ask about this.
Old Jul 18, 2014 | 11:15 PM
_demiglace's Avatar
C204, C117
That's strange, I know the --.- only shows up when you first start the car. Hopefully the dealer can answer that for you.
Old Dec 1, 2014 | 06:47 AM
Gman2217's Avatar
C300
Did you ever get this problem resolved? If so, do you recall what the fix was?
Old Dec 3, 2014 | 12:58 PM
BeaverMjr's Avatar
2015 C350 Coupe
Since the calculation was supposed to be from reset, the dealership thought the car had never been reset and did a reset to correct the problem.
Old Dec 3, 2014 | 07:28 PM
Gman2217's Avatar
C300
Appreciate the response, thank-you!
