2014 C250 Adaptive Headlights - High Beams - How to leave on?
Old Oct 17, 2014 | 09:20 AM
Sparky4688's Avatar
ML350
Anyone know if the high beams on the Adaptive headlights can be selected on? You can pull the signal lever towards you and the high beams come on as long as you hold the lever. Is there a way to leave HB on without having to hold the lever? If you hold the lever longer than about 1 minute then the HB selection on the lever is disabled and the headlight switch has to be cycled off/on to re-enable the HB turn signal lever selector.
Old Oct 17, 2014 | 09:52 AM
equetefue's Avatar
17' C43 Sedan
in my CLS you just push the stock forward until you see the headlight sign with an "A" on it.
Old Oct 17, 2014 | 01:23 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Not to sound like an ***, your owners manual clearly shows how all the features of the car work......including the high beams
Old Oct 20, 2014 | 06:01 AM
Sparky4688's Avatar
ML350
You smell like on too.... not in the owner's manual
but found the answer on the more helpful benzworld forum.
Old Oct 20, 2014 | 07:07 AM
equetefue's Avatar
17' C43 Sedan
Well just my two cents here, but you should really read the manual. There is a lot of info in there that it might not even come across as a question to post in the forum, and you might miss as a feature in the car.
Old Oct 20, 2014 | 12:00 PM
capt_paul's Avatar
Originally Posted by Sparky4688
You smell like on too.... not in the owner's manual but found the answer on the more helpful benzworld forum.
Sparky needs a spanking and put in timeout
Seriously, you need to read your manuals. THEN if you can't find the answer, then feel fine to ask on the forums.
Old Oct 21, 2014 | 06:27 AM
azarc's Avatar
2018 GLC300W
As @Capt_Paul said, you should check the manual first. He really isn't being a jerk -- he's just stating a fact.
What you're looking for *is* in the manual on page 109.
http://www.mbusa.com/vcm/MB/DigitalAssets/pdfmb/ownersmanual/2014_C_Coupe.pdf
Old Oct 21, 2014 | 03:10 PM
Sparky4688's Avatar
ML350
Thumbs down
http://www.mbusa.com/vcm/MB/DigitalA...14_C_Coupe.pdf
Not helpful!
Sparky4688's Avatar
ML350
Thumbs down
Not helpful!
Old Oct 21, 2014 | 03:45 PM
equetefue's Avatar
17' C43 Sedan
