Bluetooth Audio / AUX
Old Sep 4, 2015 | 05:53 AM
garryparmar's Avatar
Mercedes C300
hello, I own a Mercedes C300 2012. I have navagation and hands free. I cannot find an aux input in my vechile (checked glove box and arm rest area). When I try looking for bluetooth audio I cannot find it in the menu's. I just need to play music from my iphone 5s to my car. help?
Old Jan 13, 2016 | 02:41 PM
DuckySaysQuack's Avatar
2009 C300 4Matic Sport
Not sure about your 2012 model, but I know with 2008, 2009, and 2010, the 3.5mm wire is hidden in the glove box if you have the ipod connector. You need to open the glove box and pull the side paneling apart (easy) on the right (open the passenger door) and there should be a 3.5mm female jack in there.
Old Jun 7, 2016 | 10:29 PM
HighSun_Murder's Avatar
C43 AMG / C350 Coupe
Alternatively, you can access the additional audio input options by Highlighting the word Audio, and pushing down on the command wheel.
Old Mar 14, 2018 | 03:57 PM
57staff's Avatar
2008 CL550
Giving this thread a kick to ask a question about latest BT receivers and DAC devices. I just picked up a 2003 SL55 and I immediately want to upgrade the audio. Would love a new head unit but not sure what my options there are. Not willing to go with the Chinese thing.
Last word on this in this thread was using iStreamer in line with the iPhone connecting to the EQ. I am reading about a DAC that receives input via Bluetooth - the AK XB10. This unit provides both aptX (16-bit) and aptX HD (32-bit) decoding depending on your broadcasting device.
Looks like this could replace the standard BT receiver in the diagram and the DAC unit. I would still have this output go into the EQ via the AUX-IN port.
Anyone try one of these or similar devices?
Thanks.
Old Jan 15, 2019 | 02:53 PM
hebsan's Avatar
2005 SLK 350 w AMG / 2008 C / 2019 A220
Sheesh! 10 years owning my 2008 C300 and I didn't know the AUX port was hidden behind the panel to the right of the glove box. When I originally got the car, I had an iPod which worked great. As technology advanced and going through different iPhones, the iPod connector became a dinosaur and was just sitting there. I recently tried a 30pin to lightning adapter which of course did not work. After looking at this thread, I went out to my car and sure enough there was the AUX input! It took less than 5 minutes to remove the iPod cable and attached the AUX input to the inside of the glove box. I will now need to get a lightning to 3.5mm connector (that shouldn't be a problem) so that I can listen to my iPhone through the entertainment system.
Old Jan 20, 2019 | 03:04 PM
BigYAK's Avatar
2007 S550
I just purchase an 2007 S550 and i see the same Missing AUX problem. Amazon shows this product
Amazon Amazon
Can someone comment if anyone has used this product ?
Any other alternatives to stream music from Samsung Note 9 Android to the Car Entertainment system ?
Thank you !~
Old Jan 29, 2019 | 06:15 PM
daboi20's Avatar
2008 s600
https://www.amazon.com/CoolStream-Bl...adapter+carpro
Thank you !~
I use this product in my w221 streaming mostly off multiple iphone models. Sound quality is fantastic, connectivity is seamless and stable. I havent had it disconnect on me even a single time. Music streams perfectly from Apple Music/iTunes, Spotify, youtube, and many other audio enabled apps (including facebook). The only trouble I have found is when streaming from Tidal or from SoundCloud. With these 2 apps only, the audio buffers a few seconds before playing. With these 2 apps only, also, SOMETIMES you have to press play multiple times before the song actually plays. This happens with these two apps one out of 10 times. Again, only with Tidal and SoundCloud. So far the other streaming apps have played back perfectly and without incident. To add, I've been using this bluetooth interface for close to 2 years, almost daily usage.
Old Mar 15, 2019 | 01:58 AM
IKnowAGuy's Avatar
C300 Sport Sedan 2011
I just bought a 2011 C300 sport. My radio doesn't even have an aux or mp3 input, but i can't find anywhere that addresses upgrades for this model head unit. All I have is Radio and CD and when you press CD button, CD is the only option shown. Any links to a complete unit upgrade? Thanks!
Old Mar 15, 2019 | 03:42 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Hmmm....have you read the owner,s manual and the COMAND manual?
Old Mar 15, 2019 | 05:10 AM
MBpippo's Avatar
2013 C204 C250 Coupe
Did you try this?...
Originally Posted by DuckySaysQuack
...the 3.5mm wire is hidden in the glove box...
Or this?...
...open the glove box and pull the side paneling apart (easy) on the right (open the passenger door) and there should be a 3.5mm female jack in there.
Old Dec 2, 2019 | 05:49 PM
gage Sherlock's Avatar
Mercedes
Or this?...
wait this works for a clk 350 2009?
Old Dec 2, 2019 | 05:51 PM
Mercedes
wait is this true for a clk 350 2009??!!?!
