2012 C250 Engine part, Pls HELP
I have 2012 Mecedes C250 Coupe and today I realized one plastic part in engine is half broken both side(up and down) and does anyone knows what is that part and does it make any problem if I will not change? It is on the passanger side of the car up front. any info about it?
I have a good used one if you need, the new ones aren't too expensive though, should be under $300.
An easy and perfect fix is to simply use plumbers tape to make the air seals right.
