2013 c250 misfire
2013 w204 c250 coupe & 2001 Dodge Ram 2500 24v Cummins
if you haven’t changed all the spark plugs and coils I suggest you do that. They all work in tandem with eachother and if one is out that means the others have to work harder to pick up the slack of the misfiring cylinder.
that would be my first suggestion is to do an ignition service.
ant
chassis (04-19-2024)
@junk405
Did you clear the code after you changed all the plugs?
It could be your coils that are bad as I also suggested previously.
Did you visually confirm there is no spark going to that misfiring cylinder plug?
Ant
Ant
I Would look at injectors next then. Since you're confirming there is spark and the coils are good.
IS there any oil collecting/pooling in the spark plug hole? You could have oil collecting and causing a miss fire. Was the plug/coil oily when you pulled it out? This would be a failed spark plug gasket on the valve cover. There is 4 smaller gaskets that surround each coil and plug.
Have you ever done a fuel treatment? Or replaced the pumps in the tank? That's where the fuel filter is located. Best case is a dirty injector.
Ant
Ant
Received 3,948 Likes
2017 GLE350 4MATIC
Change all coils.
Check cam sensor and cam magnet electrical harness connectors for signs of oil.
Check O2 sensor connectors and injector connectors for signs of oil.
Does this engine have tumble flaps in the intake manifold?
antboii (04-21-2024)
