Aftermarket wheels for C class coupe
Subscribe
Jan 6, 2019 | 05:25 PM
Looking for pics of your 2017+ mercedes c class coupe with aftermarket wheels. I currently have the oem 18" 5 spoke wheels and looking to replace them with either the 19" amg multispoke or some aftermarket 19's. I've searched and can't seem to find pics of aftermarket wheels on these cars. Thanks in advance!
Reply 0
Jan 7, 2019 | 07:41 AM
Not the best quality pics as the weather has been terrible lately, but here are a couple that I snapped prior to lowering with H&R springs. The wheels are Vorsteiner V-FF 107's (19x8.5 front/19x9.5 rear)
Reply 0
Jan 7, 2019 | 09:42 PM
Those are some very nice wheels. 19” are a must, I have the 19” AMG multispokes and am thrilled with the choice.
Reply 0
Jan 30, 2019 | 01:26 PM
I ended up going with the 19" AMG multispokes. However from going from the 18 to 19's the rear ride height is about 0.3" higher than before so I'm looking to get it lowered a bit. This is a 4matic with the 677 avantgarde/standard suspension. After doing some research it looks like my options are the H&R sport springs or the Eibach pro kit. These will lower the car about 1" and I'm just wondering with that drop would there be any rubbing or issues with speed bumps etc? Thanks in advance
Reply 0
Jan 30, 2019 | 01:40 PM
I have the sport suspension, and went with the H&R springs (my original reply with pics above were pre-install). My drop ended up settling at just over 1", though with the standard suspension you should expect closer to 1 3/8". Installation was a bit trickier than I had planned for, but I am very happy with the results! The car looks much more aggressive, without looking slammed.
Reply 0
Jan 30, 2019 | 01:49 PM
Quote: I have the sport suspension, and went with the H&R springs (my original reply with pics above were pre-install). My drop ended up settling at just over 1", though with the standard suspension you should expect closer to 1 3/8". Installation was a bit trickier than I had planned for, but I am very happy with the results! The car looks much more aggressive, without looking slammed.
Thanks! I believe my suspension is the same height as the sport so I'm expecting a 1" drop as well. There's currently about a 3 finger gap. Have you experienced any issues with rubbing or with speedbumps or scraping down driveways etc?
Reply 0
Jan 30, 2019 | 01:52 PM
No clearance issues at all. The ride is a just bit firmer, but I actually prefer it.
Reply 0
Jan 27, 2020 | 01:02 PM
Would you mind posting the model number of your H&R springs?
Reply 0
Explore
Jan 28, 2020 | 11:01 PM
Reading through - certainly costly and time consuming effort!
Too late, but do point out for a total outlay of $380 #502216-2 kit provides:
1. Not only precise adjustment front Camber but Caster as well to compensate for the Camber change.
2. Up to 1.5 degrees extra Positive or Negative (5 times that of the inaccurate - "one only offset position "fluted bolts).
3. Replacing the upper arm inner bushings. Fast fit on car "with no need for arm removal or special tools required. Bush extraction tool is included.
4. Last but not least - security, peace of mind of retaining the original high strength alloy OEM arms!
For extra performance, track days
Front "Replacement" Upper Arms - same as OEM high strength forged alloy. Precisely Camber and Caster adjustable up to 2.5 degrees extra Camber and Caster $695 #502216-3 (both sides).
Along with front "lower arm" Camber and Caster bushings.
These replace the 4 front highest wearing suspension bushes at the same time.
Providing a further 1.5 degrees extra (Pos or Neg)Camber plus 35mm extra track width.
The forward facing thrust arm bushes are Mono ball / 2 Axis self aligning. Significantly improving brake and steering response. Have more than twice the load bearing area of spherical bearings that soon pound out $480 #502216 K
FOR THE REAR:
Lower arm inner bushes for Camber (extra 1.5 Pos or Neg) plus 35mm track width. Includes extra Toe adjustment to compensate for the new rear Camber facility.
This design unlike "upper arms" retains top of tire to outer fender clearance if wanting to reduce inner edge tire wear $480 #502526
While upper Camber arms. Not welded, fabricated or extruded aluminum but OEM design high strength forged alloy. This kit includes extra Toe adjustment as well.
Upratd bushings for the 6 multi link rear arms. Less twitch, flex, loss of traction especially when applying power. to lane change / overtake $480 502528 K (AMG #502528-1 K $480)
Reply 0
Subscribe
Currently Active Users (1)
