DMP Car Design Ambient Lights don't turn off when car does....
I managed to get the driver's side door and foot wells installed to test them, and It took me a bit to figure out how to control the lights as for at first they were just flashing thorugh the rainbow and I couldn't change that. Finally I was able to. All is well except one problem, the lights stay on even with the car is off, locked, and I am far away from it with or without keys. In fact no matter what I do the lights just stay on unless I manually dim them to dark/off but I am worried somehow they are still draining juice from my battery. Does anyone have a solution for this?
***Also, one quirk: the driver-side module with a 3-wire passthrough (as discussed in post #18) that connects to the mirror switch I received did not have the little plastic part (aspect of the connector that only allows it to be connected into certain-shaped connections) on the correct side, instead it was on the opposite side and would never in a million years connect to the mirror switch... so I had to file it off in order to connect it to the mirror switch. There are no other 3-wire passthrough ports in site so I am unsure what this was about or if it was meant for a R-sided driver/European car or something of the sort. Perhaps this is the issue?
I did contact DMP and am awaiting reply but will try to keep updates flowing. Just trying to get these darn lights off when the car goes off! Thanks.
