Navigation question
Old Oct 4, 2024 | 06:55 AM
Old Dawg's Avatar
2022 EQS 450+, 2020 C300 Cab, 2019 Jeep GC
Navigation question
Looking for some help understanding. I just purchased a nice 2020 C300 Cab. Looking on line it seems to make a difference that the car has the wide screen display.
The window sticker provided by the dealer (not MB) has the item "turn by turn navigtion directions", on the driver's screen there is a navigtion icon and there is a nav button on the center console.
There was no SD card so I did research and purchased one labeled as A2139069807 as it was the only one that seemed correct for the wide screen setup.
When I plugged it in nothing happened and I am wondering if the Nav system actually exist and asking if any of you have a car without the Nav system did MB still put the icon and Nav button on the car. Or did I just get the wrong SD card.
Thanks for you help
Old Oct 4, 2024 | 01:19 PM
superswiss's Avatar
2019 C63CS
There are two navigation systems for the 205. The entry level one which is SD card based, and the full built-in one with online services that is part of the Multimedia package. The latter does not require an SD card and the maps can be updated online, either via OTA update or via full download and updating from an SD card or USB stick. The navigation button will always be there in the car, but it won't do anything if navigation hasn't been fitted. In order for the SD navigation to work, the car must be fitted with the SD navigation preparation option from the factory. It should say something to that extent on the sticker. If it wasn't fitted with that option, then the SD card doesn't work. I believe if you have the SD card slot, then the option is there, so you likely have the wrong SD card. It's a different system as of the 2019 FL models, so you may have bought an SD card for the PFL version.
I don't have a screenshot of the SD prep option, but here's the Multimedia package option for reference.
Old Oct 4, 2024 | 06:24 PM
Old Dawg's Avatar
Thanks. I definately don't have the Command system.
I do have the SD card slot in the center console, along with the wide center console screen. So the remaining question is what SD Card do I need. All the others I find seem to refer to an "Audio 20 (Code 522 System)"
Any further help is appreciated.
Old Oct 4, 2024 | 06:35 PM
superswiss's Avatar
2019 C63CS
To be honest, I don't really have enough experience with the SD card navigation system and most people get full COMAND if only for CarPlay/Android Auto support. As far as I remember, the SD card navigation doesn't even have live traffic, so it's a pretty dumb navigation system. Also, the online sources can be shady. The problem is the SD card gets locked to the vehicle's VIN the first time it's inserted, so many of the ones you find online are scams. They have been used before and are locked to a specific VIN, so they won't work in another car. Your best option is to head to your local MB dealership's parts department and give them your VIN. They can order the correct one, or at least give you the part number if you wanna try to buy it online from a reputable source.
Old Oct 7, 2024 | 09:22 AM
Old Dawg's Avatar
I am becoming convinced that my car isn't prewired for Nav, dispite the "window sticker" but would like to confirm one way or other. Can someone please confirm that even without the SD card inserted you get some kind of message when you push the Nav button on the dash. My button does nothing and when i select Navigation on my steering wheel the drivers display just says "please wait".
Old Oct 28, 2024 | 04:59 PM
Kingdom818's Avatar
2019 Mercedes c300 4matic
Has anyone gotten a used MB without the navigation SD and then gotten the navigation SD later? Mine didn't come with one. I'm curious how much something like this would cost from a dealer since the ones from ebay seem pretty sketchy.
Old Oct 29, 2024 | 11:18 PM
Jhopk4's Avatar
2020 C300 Cabriolet
MB Entry Navigation on '20 CAB
Mine is a '20 Cab with Audio 20 Nav, not Command. The build sheet includes the following items necessary for the navigation experience.
270 GPS Antenna
355 Pre-Installation for SD-Card Navigation
367 Live Traffic
362 HERMES Communications module LTE
448 TOUCHPAD
506 Audio 20 Headunit 5*5
859 10.25" Color Display
Basically, this combination starting in '19 was called "MB Entry Navigation". It is a full navigation system with great graphics, including 3D buildings and Live Traffic and is quick and accurate. With MercedesMeConnect active, it also includes Weather and online location search "Around me". So if a newer destination exists that is not on the card from 2019, it still finds it and presents it as a destination to the Navigation. I can also search destinations in the iPhone app and "send them to Benz" as well.
The only thing needed to make it fully functional is the "brain" or appropriate SD card. I had it loaded on mine at purchase delivery. The MB part was #A213 906 55 08. The packaging shows it was not Garmin or TomTom but rather "Here" by Navis Automotive Systems. When I look up that part, it looks like it has been superseded by #213-906-38-08-64. Here is a link to MBPartsStore selling the current card: https://www.mbpartsstore.com/oem-par...d-213906380864
Also, here is a link to a blog that really explains the difference between all of the navigation options between '19 & '21 that you may find helpful: https://mbzmaster.com/2019-mercedes-...pros-and-cons/
Old Oct 30, 2024 | 01:45 PM
Kingdom818's Avatar
270 GPS Antenna
367 Live Traffic
448 TOUCHPAD
Thanks for the response! I'll look into it some more. If I'm understanding correctly all I need is the SD card and I'll be good to go.
