WHeels
Old Mar 14, 2005 | 10:54 PM
1997c230's Avatar
WHeels
Hey Guys,
Will 8x8.5 inch wheels all around fit on a 97 c230 with a 1.25 inch drop?
Old Mar 15, 2005 | 11:11 AM
!!!!!NJ Drive's Avatar
yes.... depending on offset
Old Mar 15, 2005 | 06:40 PM
1997c230's Avatar
How about with a 35mm Offset? I've done a search and found many discussions stating that 8.5 inch is the wides tire you can fit, but you need to roll the fenders. I can see rolling the fenders in the rear but the front doesn't look like it has any room to roll the fenders since they are already partially rolled upwards.
Can anyone here with a simmilar setup, 1.25 inch drop and 18x8.5's chime in, I'd like to hear your oppinions and any advice youd have as well as any problems you've encountered.
Thanks,
J
Old Mar 17, 2005 | 01:08 AM
manong's Avatar
with a 1.25" drop, what spring pad are you using? next thing is the front fender can definitely be rolled, mine is. my wheel set up is 18 x 8.5, 30 offset for the front and 18 x 9.5, 32 offset. so the wheels of 18 x 8.5, 35 offset will be just fine with minor front fender rolling only. hope that helps.
Old Mar 17, 2005 | 10:05 PM
tpliquid's Avatar
too poor now
u need to run 225/40/18 front and roll fenders they willw ork
u will get rubbing when u u turn fast. dats abuot it.
Old Mar 18, 2005 | 07:57 PM
DougandhisC280's Avatar
2008 SLK-280
I recommend 18 by 8. That's what I have. If it was a centimeter bigger I would rub all the time. I have about a 2 inch drop with Carlsson springs.
