How do you remove the side mirror covers?
Old Aug 31, 2006 | 07:41 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Question How do you remove the side mirror covers?
I remember seeing a post but can't locate (it said something about a clip). I see the clip but it doesn't want to snap out of place. What's the trick? Thanks.
2000 C280
Old Sep 2, 2006 | 12:02 PM
trbo2nr's Avatar
I figured it out. Bend the mirrors forward and the flat C clip needs to be removed. Afterwards, the cover slides right off. Anyone doing this I would suggest replacing the clips because while they flex, it's hard to flex them back to original position and mirror cover won't fit snug.
Old Jul 7, 2007 | 01:15 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
I came across this older thread while searching for info about the OEM mirror assembly.
To set the record "straight" the thin metal C shaped clip is NOT a replacement item, it is part of the $600 mirror/motor assembly, so don't break it.
