Noise has me stumped!
Old Dec 30, 2006 | 01:11 PM
Don C230's Avatar
1997 C230
Question Noise has me stumped!
I have got a noise that sounds like it is coming from the left front wheel of my 1997 C230. The sound is similar to the harmonic whine of out of round rotors / undampened pads. It only occurs at very low speeds (under 10 mph), while the wheels are turned to the left about a third or half way to lock, with or without the brakes being applied, and usually (but not always) after the brakes have been used in traffic. It started right after I had the front brake pads, rotors, shocks, and wheel bearings replaced. I have taken it to both the independent tech who performed the other work and another locally respected independent tech. None of us have been able to locate the problem. I would appreciate any ideas.
Thanks in advance for any and all insight,
Don
Old Dec 30, 2006 | 02:14 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Don
I have the same problem. I have no f-in clue what it is...here is my post asking about it:
https://mbworld.org/forums/mercedes-tech-talk/169558-humming-sound-wheels-not-bearings.html
Old Dec 30, 2006 | 02:31 PM
Don C230's Avatar
1997 C230
Noise
OCKlasse,
Very much appreciate the reply and link (was not able to spot anything like issue using searches).
While I do see some significant differences (noise only at low speed with or without brakes applied, and only when turned to the left), it is similar. Thanks to the post by 516mbtek I will also check the rotor backing plate and seriously inspect the tires.
Again, any ideas put me farther along than before!
Don
6 Father's Day Gift Ideas Your AMG Loving Dad Will Cherish
Slideshow: Six Father's Day gift ideas your AMG loving dad will cherish.
By | 2026-06-03 16:34:48
