Humming Sound from Wheels - not Bearings
Old Nov 6, 2006 | 01:05 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hey guys I have this loud humming sound (sounds like when you have a bad bearing) coming from my front wheels. I have just replaced the front wheel bearings, but the noise is still there. It is worth noting that I have Zimmerman cross-drilled rotors and Akebono ceramic pads, but I don't think the sound is brake related. In fact, when I push on the brake, the humming stops. Any idea what this could be from? Thanks
Old Nov 13, 2006 | 07:00 PM
OCKlasse's Avatar
MBworld Guru
any ideas?
Old Nov 13, 2006 | 08:49 PM
mbtech360's Avatar
What kind of tires do you have?
Old Nov 13, 2006 | 11:47 PM
OCKlasse's Avatar
MBworld Guru
Dunlop SP Sport FM901s in front SP Sport MAXX's in the rear...could it be them?
Old Nov 14, 2006 | 12:17 AM
516mbtek's Avatar
'06 CLS55 P030
sounds like a tire...run your hand around the tread area and see if it feels choppy...check for cupping
Old Nov 14, 2006 | 12:28 AM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
+1
Old Nov 14, 2006 | 01:37 AM
OCKlasse's Avatar
MBworld Guru
except even when I had the stock wheels on the car, it made the noise...I just remembered that.
Old Nov 14, 2006 | 04:31 PM
lkchris's Avatar
'10 CL550, '12 GL550
I agree, sounds like a tire.
Take a look and see if it says GOODYEAR.
Old Nov 14, 2006 | 06:07 PM
OCKlasse's Avatar
MBworld Guru
It's not tires...when I had the stock wheels in between wheels, it still made the sound...
Old Nov 15, 2006 | 12:59 AM
516mbtek's Avatar
'06 CLS55 P030
lol
Old Nov 15, 2006 | 01:07 AM
516mbtek's Avatar
'06 CLS55 P030
Check your tires anyway. Check ur brake install make sure the wheels spin free when jacked up---make sure backing plate isnt contact the rotor at any point, but I seriously doubt a brake issue---> Check your driveshaft tunnel insulation, make sure its not hanging down....if not that than its a bearing..change the bearings, inner and outer, make sure you pack them properly, change the RACES, and seals.
Old Nov 15, 2006 | 03:16 AM
sick430's Avatar
CLK Cabrio
dude whats up, i have the same humming sound i have the cross-drilled brembos. when you press on the brake it goes away right. its the air flowing through the rotors. i think there maybe a problem with the pads being to close to the rotors and causing the hummming sound on mine. just my 2 cents. upgrading front brakes to c32. see what happens
Old Nov 15, 2006 | 12:54 PM
OCKlasse's Avatar
MBworld Guru
thanks for the heads up man! yeah the sound goes away when you press the brake. I was wondering if it could possibly be from the cross-drilled rotors...let me know!
Old Nov 20, 2006 | 08:55 AM
Matt@Revolution's Avatar
1972 280SE 4.5, 1966 220Seb (under restoration), 1993 300TE (3-kids), 2003 Stella (commuter scooter)
It's definitely the pad rotor combination. I say either go back OE or learn to live with it.
Old Nov 20, 2006 | 11:09 AM
vettdvr's Avatar
03 E500 and Corvette
I just removed a set of tires because of the same issue. My noise was speed related and changed with speed. It might be alignment causing the cupping. This has been a MAJOR issue with my E500. Jim
Old Nov 20, 2006 | 01:46 PM
bltserv's Avatar
2005 SL55, 2000 CL500
Humming Wheels
When I first got my SL55 I thought for sure
it had a wheel bearing going. Just crappy Pirelli`s
making that noise. It was loud and you could feel it
through the brakes from about 5-20 MPH.
It seemed like it was serious issue. Or so I thought.
My SA said it was tires. He once again was correct.
Got new Michelin Pilots. No more Humming.
Old Nov 20, 2006 | 08:57 PM
MBTech21's Avatar
05 ML350, 85 300D
The thing you guys are missing is tire noise doesn't go away when you touch the brake- its the holes in the rotors.
Old Nov 20, 2006 | 10:12 PM
516mbtek's Avatar
'06 CLS55 P030
sometimes it seems like the (tire) noise goes away when hitting brakes cause the car slows mabe to a speed in which the noise dissipates...I have been a victim of this myself thinking its a brake issue when really a tire. This type of noise is 9 out of 10 times a tire in the real world...but then again this is MBworld so who knows. I have driven loads of cars w/ cross drilled rotors and never really heard any noises....but thats not saying its impossible....slotted rotors on the other hand thats a different story.
Old Nov 20, 2006 | 10:21 PM
MBTech21's Avatar
05 ML350, 85 300D
Again,,,,he is not saying slowing down..he is saying touching the brakes..there is a difference. Brake noise comes from pad vibration..period, you touch the brakes, the calipers apply force, the vibration has to stop....like the old 'squealer' wear indicators. Could even be the ceramic face of the pad, vibrating off the drill holes, with out the proper vibration damper- it will make noise..
He even makes a point of saying..it made it with different wheels/tires on the car....and another guy with the same car/rotor combo had the same noise..hmm maybe we are beating this to death...
Old Nov 20, 2006 | 10:46 PM
516mbtek's Avatar
'06 CLS55 P030
why dont you go over to his house, charge him $100, perform a road test with the client.... after which perform a complete veh inspection then make ur diagnosis? that may be easier?
Old Nov 21, 2006 | 10:12 PM
MBTech21's Avatar
05 ML350, 85 300D
your point, young padua?
Old Dec 5, 2006 | 06:12 AM
mcleantmw's Avatar
2003 E500 Benz & 2015 BMW M235ix
Which Michelin tire and size did you get? I will be upgrading my existing wheels to 18" AMG alloys in a couple months and want a smooth riding and quiet tires. Summer tires are better than M&S tires for this I believe and Luke on the Tire tread here recommended Goodyear Eagles.
