cruise control stop working
C36 AMG
few days ago decide to sort out the inconstant iddle and sent C230 to the garage to replace air flow meter. idle better but cruise control not workinng anymore. mecanic suggestet to replace few more parts but I am not sure at all that he is right. anybody had simmilar problems? thanx
C36 AMG
cruise control
they are a great tool for long distances and fuel economy. c230's one was great till the car went sick...for the moment is in limp mode.
Have you tried resetting things via a battery disconnect or a handheld scanner? I would reset things and then start checking for codes that reappear to see why it is going into limp-home mode.
You are going to have to put out some effort and be more descriptive if you expect anyone to be able to help you trouble-shoot this. Exactly what codes is your car producing?
1998 C 230
2 things it may be
(1) If you have used the cruise control often or it is a second hand car: unsure of the past useage then it may be the lever itself malfunctioning.
Check for slop in the lever itself, the switch may be worn if this is the case.
(2)The cruise control has an amplifier module in the circuit that may have gone bad. Check to see if you have any function of the lever itself with a triangle actuating on dash. I had one replaced luckly under warranty, very $$$ unit.
1998 C230
The cruise control on my '98 C230 just stopped working as well. There are no lights or other indications of a problem and the switch seems tight.... is there a fuse that might need replacement??
