2 wrench service light
I have read and read all the tech's on shutting of the service light but it will not work for me for s@#t.
The only thing I think is different is that there are 2 wrenches instead of one.Could that be a different proceeder? 98 c280 Sport
![action](https://mbworld.org/forums/images/smilies/action1.gif)
1 wrench = Service A
2 wrenches = Service B
1. get in the car and shut the door.
2. put the key in the ignition and turn it to position 2
3. tap the reset button twice to make it bring up the service due indicator
4. hold the reset button with one hand and with the other hand cycle the off and back to on.
5. after a few seconds it should reset.
you might also try this; when cycling the key off and holding the reset button, release the reset button and then quickly depress it again and hold it while cycling the key back to position 2
I thank you and will try that.I do have to say that trying all this button pushing I got a weird reading in the display 2.8 and 2 other numbers I think 78 but not sure.I assume that 2.8 is the engine litre but the other two I don't know.Any ideas what they may mean?
MB-SI Reset © Baum Tools Technical Publication September 10, 2002 415-566-9229 Tech Support
Mercedes Service Interval Reset
1997- 99
There are two systems present in 1997 to 1999 vehicles, for both procedures:
“BE SURE THE CAR DOORS ARE CLOSED”
Procedure 1
1) Turn ignition key to position 1.
2) Press the odometer button and hold.
3) Turn ignition key to position 2.
4) After approximately 10 seconds, a signal gong sounds and the display should reset.
5) Release the odometer button.
or
Procedure 2 (E class)
1) Turn ignition key to position 2.
2) Within 4 sec's press the odometer button twice within 1 second. Cluster should now show
reminder status.
3) Within 10 sec's turn ignition key to position 1.
4) Press and hold odometer button while turning ignition key to position 2 again, and
continue holding the odometer button.
5) After approximately 10 seconds, a signal gong sounds and the display should reset.
6) Release the odometer button.
If you make any error in a procedure, turn off ignition for 30 seconds, then turn back on to position
2 and wait for lights to cycle on dash. Turn off ignition and then restart the procedure.
ASSYST (Active Service System) - 1997 Models
FSS (Flexible Service System) - Chassis 129, 140, 208, 210 (1998-99) & 170, 202 (1999)
*Some systems can only be reset with the CS2000 or factory HHT.
Mercedes *** Reset
On the Instrument Cluster there should be a button on the
LH side with "0" on it.
1. Switch ignition on and IMMEDIATELY press button twice.
2. Turn ignition off.
3. Press button & hold pressed
4. Turn on Ignition (KEEP BUTTON PRESSED)
5. After ~10 seconds there should be a 'beep' and the
interval should be reset.
6. Release button & turn off ignition
This works with 1999 W210 E200s, so I hope it helps,
MARLARBKUFU (07-25-2019)
