95 C280 stutters and drives sluggish!!
Old May 10, 2007 | 07:43 PM
KHOLLA's Avatar
Hey guys,
I got a 95 C280 and on and off for about a month now its been driving sluggish. When strating from a stop, itll stutter and move real sluggish before itll take off. One day my mother accidently mixed premium with 89 gas and it started doing that. I thought it was the feul injectors and I put in injector cleaner/treatment for the next 3-4 fill ups, and still the same promblemo. Some one told me it could be the spark plugs or wires. Im praying its not the transmission. Does anyone has an idea of what could be the problem? Thanks, Kris
Old May 10, 2007 | 09:10 PM
l48512069357629's Avatar
W220, W140, W202
hey my car in the past vibrated and shook like crazy and was very slow. i had check engine light.so i change all the spark plugs and the wires connected to them including the boots and now car runs like new. just get the BOSCH plugs
Old May 13, 2007 | 08:58 PM
xvvvz's Avatar
C230K
Mass airflow sensor tests out OK? Or did you at least spray it down with MAF spray from CRC? Have you gone to Autozone and had them scan your car for codes for free?
Old May 16, 2007 | 03:03 PM
martz's Avatar
German
fuel filter? process of elimination. You said only started after 89 octane was filled. just my 2cents
Old May 16, 2007 | 06:56 PM
bicylindrico's Avatar
For some reason the M104 with HFM fuel injection was notorious for carbon tracking on the spark plugs. It will give a running condition like you describe. Stuttering upon heavy load especially from a stop. The plugs aren't changed frequently enough and would push combustion gases past the ceramic/metal base and contaminate the boot. You will notice tell tale black streaks down the side of the ceramic that are heavy enough to feel with a fingernail.
Everyone should be using dielectric grease on their plug boots to help prevent this. I wouldn't look anywhere else until I visually checked the plugs. Also look for the brown staining around the base of the ceramic. Let us know what you find.
Old May 19, 2007 | 12:25 PM
philkwill's Avatar
2009 SL550
If you got over 80k miles change the spark plugs.
Old Aug 23, 2007 | 05:03 AM
E=MC^2's Avatar
W203X2 w201X3 W208 W129
i have the same problem
i have a 94 c280 and it revs and sputters and is really annoying! i got new plugs and wire and also used injector cleaner i thought it might be my mass air flow meter too i havent gotten mine checked. it might be an oxygen sensor? i have no idea sorry
Old Sep 8, 2007 | 03:42 PM
pnova's Avatar
C280, 1995
same problem - dealer blames the sparkplugs
Have the same problem. Dealer did some diagnostics, and blames the sparkplugs (will be changing this week).
