2000 c230 kompressor hard stating in morning..
https://mbworld.org/forums/mercedes-tech-talk/214518-2000-c230k-starting-problem.html
Edit: I found a similar post here with answers
http://www.mercedesforum.com/archive...ld-8212-1.html
The problem that I am having lasts for just a second after starting.
Also check for oil contamination of the airflow sensor in the charge pipe. There have been issues of sticking purge valves on the higher mileage M111 kompressor motors. There are updated parts to help prevent this.
I also remember some old C220 non-supercharged engines with low stumbly idles that would need the throttle valve cleaned. When the throttle snapped shut it would stick and not allow the M16 to be able to adjust for idle speed. I never saw this issue on the supercharged M111 but the miles are getting up there for some new problems.
One time they tried filling it up with regular, which did not help at all, but did decrese the performance and fuel economy for that tankfull.
Also, it is not really a hard start, but a stall after starting.
I have also found out that it is not related to time, i.e. how long the car has sat, but based purely on tempterature. The colder, the more "certain" the stalling is.
Would that help?
1. Oil Change Mobil 1 0w-40 and OEM filter.
2. Transmission fluid and filter change (Mercedes OEM Syn ATF)
3. Differential fluid change. (SYN)
4. Coolant change. (OEM)
5. Fuel Filter Change
6. Air filter
7. Cabin Air filter
8. Spark Plugs
9. Brake Fluid Change
I hope I have not forgotten something, but I believe that was the service on the car.
6. Air filter
7. Cabin Air filter
8. Spark Plugs
I have a new fuel filter in hand now and should try replacing it in the next few days. I should be reporting any success, I hope.
Dealer wants 200+ to replace the filter. It is easy to access just under the right side raer passenger area near the fuel tank. If you take the part to a local mechanic he may be able to replace it for you cheaper/.
I usually buy these parts at :
germanstar.net they have good rates and you can call and talk to a person who knows what they are selling.
