new W202 owner...........
Old Sep 5, 2008 | 06:57 PM
rustee's Avatar
1996 C280
Hi everyone i just got my Car about two weeks ago.....it is a 1995 C280 and i have a few problems......BTW i love this car but,
the door lock don't work
the SRS light its on
and sometimes when i have it on D and i wanna put it on Park it won't let me it gets stuck so i have to drive for a while and then its ok
and the temp gauge jumps from 80 to 100 while im in traffic
any help would be appreciated
Old Sep 6, 2008 | 07:05 AM
Untertürkheim's Avatar
Do you know the last time the coolant has been changed? If not, flush and refill with MB coolant.
You will have to read the code for the SRS light, and you should really get it fixed, your airbags may not work in an accident, worst case scenario they go off while you are driving and cause an accident.
When was the transmission last serviced? If you cannot answer this, it's time. 9 Quarts Mobil 1 Synthetic ATF, and an MB filter/seal kit.
Old Sep 6, 2008 | 03:07 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
for the door locks- open ur trunk take the carpeting on the right side down. find the yellow vacuum tubes and where they all meet together there is probably one that popped off the connector. if this isnt the case u may need a new vacuum pump(if one of the tubes is popped off ull hear the pump in the trunk trying to lock the doors for like 5 seconds, if u dont the pumps dead), or you may have a leak in the line behind your dash which sucks to get at.
Old Sep 6, 2008 | 07:58 PM
rustee's Avatar
1996 C280
i already looked at the pump but i dont hear anything so i thinks its dead
thank you
Old Sep 6, 2008 | 08:00 PM
rustee's Avatar
1996 C280
is there a DYI on how to do all of these? i looked under the car but its all cover up :P
thanks for your help!
