Air in fuel lines - retrofit kit
Old 12-21-2008, 12:53 PM
Loosepube's Avatar
C250TD X 2
I have changed all of the 'o' rings, including all of the fuel lines. I have also replaced the Pre-filter 'o' ring and the IP and heat exchanger.
I contacted http://www.mercedes-benz-parts.co.uk/ for advice on this problem. They stated that I had low pressure in the fuel lines and quoted a retrofit kit part number A2024700193. The kit was £100.84 inclusive.
I purchased the kit from them but it has arrived without any fitting instructions. The bag of bits includes part number A2024760432 (valve?)and has two wires on it (Blue and yellow) which are pre-terminated. In the kit there is also two rubber fuel pipes, loads of clips and jubilee clips. I have contacted Inchcape for further information, but so far no joy.
Can anyone help please - if you know about this kit do you have a copy of the fitting instructions? There is no reference to these part numbers on the EPC parts system I have.
Old 12-22-2008, 06:39 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
PM me your fax number (inc country code) or email address, I'll send you the instructions, I've just realised what kit you're talking about.
In the meantime where is the first point that you can see air in the fuel lines?
Attached Thumbnails Air in fuel lines - retrofit kit-fuel-lines.gif   Air in fuel lines - retrofit kit-fuel-lines2.gif
Old 12-22-2008, 09:10 AM
Loosepube's Avatar
C250TD X 2
Air in fuel lines
Hi, sorry I do not have a fax machine. My email address is a.scheffel@btinternet.com.
Many thanks for you help.
Old 12-26-2008, 12:04 AM
Ausmbtech's Avatar
Emailed to you.
Old 12-30-2008, 03:30 PM
Loosepube's Avatar
C250TD X 2
All sorted - problem solved. Many, many thanks for your help.
Old 12-30-2008, 05:49 PM
$tallion's Avatar
97 C28
Gotta love this website thanks too everyone who makes it what it is amazingly enjoyably mbworld.org!
Old 03-23-2009, 02:10 PM
patakka's Avatar
W210/W202/W164
Air in fuel lines-retrofit kit
Hi,
I have the same problem about that "kit".
Can you please email the instructions for me mr Ausmbtech.
My problem is line nr 32 , diesel oil drops back when I got the engine off.
P.S My english is bad sorry , because we speak dutch in my country .
Kind regards,
patakka.
Old 03-24-2009, 01:06 AM
Ausmbtech's Avatar
Is the air entering from the fuel filter end of line 32 or the other end?
If it's entering from the fuel filter end then replace the pre-fuel filter (155)and o-rings (2 orings). If it's from the other end then replace the fuel pre-heater. The seals are leaking in the pre-heater now that these engines are getting older.
Do you also need the retrofit instructions?
Old 03-24-2009, 09:43 AM
patakka's Avatar
W210/W202/W164
air in fuel lines- retrofit kit
Thanks Ausmbtech ,
I don't know from where the air is entering, because I can't see any air bubbles in the pipe line.
The only thing I can see is that , when the engine is off the diesel oil drops back 3 cm (see photo ).
There are no leaks of diesel and no smell .
I have almost replaced every part such as : all of the 6 oil fuel lines, all of the o-rings, feed pump ,heat exchanger, 6 glow plugs, shutt off valve, fuel hoses, fueltank filter + o ring, clamps, pre -filter and diesel filter.
If the engine is running there are no air bubbles in the 6 oil pipe lines.
So my last attempt is the retro fit kit , you can mail that for me.
Kindregards ,
patakka.
Attached Thumbnails Air in fuel lines - retrofit kit-w210-e-300-td-bj-1998-030.jpg
Old 03-25-2009, 08:27 AM
Ausmbtech's Avatar
Unless you are having starting difficulties after sitting overnight then I doubt the retrofit kit will help you. It was only designed for W202's with 604, and 605 diesels. It could also be retrofited to your W210 with the 606 engine but I would want to rule out all possible leaks first (only if you have a starting problem). A little air without a starting syptom is nothing to worry about.
When you replaced the pre filter, did you replace the oring on the filter (must be ordered seperately) and the oring on the fuel line that attaches to the pre filter? they are the likely suspects.
Sent you a PM
Old 03-25-2009, 10:11 AM
patakka's Avatar
W210/W202/W164
Sent you a PM
Hello Ausmbtech,
Yes the o rings are replaced , even the nozzles are inspected there are no leaks.
I almost always have starting problems, no matter whether the car stood still for a day.
It always starts at a second attempt , and when the engine is hot its gets even worse.
Kind regards,
patakka.
Old 11-24-2010, 11:22 AM
Thomas81's Avatar
W202 250TD
I going to install retrokit a2024700193 on my W202 250TD, but i don,t now where i have to place the parts in the fuel system. One that has a manual or a picture where i can see it?
Thomas
Old 11-24-2010, 01:31 PM
patakka's Avatar
W210/W202/W164
retrofit kit
Hello , pm mr Ausmbtech , he had helped me at the time with a pdf file , about the retrofit kit
Old 12-20-2010, 01:35 AM
MyMercC250's Avatar
C 250 TD 1998
Cool Joe
Thomas
Hi Thomas,
What`s your e-mail address ?
Old 12-20-2010, 02:55 AM
Thomas81's Avatar
W202 250TD
Originally Posted by MyMercC250
Hi Thomas,
thomas_81@live.dk
Old 12-30-2010, 07:16 PM
Thomas81's Avatar
W202 250TD
i have the WIS software now, but i can't find what i have to do.
Old 02-05-2011, 01:28 PM
patakka's Avatar
W210/W202/W164
fuelline
Check your email
Old 03-16-2012, 01:17 PM
VPGALAMBA's Avatar
mb250td
Hello,
could you please send fitting instructions of A2024700193?
thanks in advance
vitor Galamba
Old 10-25-2013, 10:35 AM
joaojero's Avatar
w201
Originally Posted by VPGALAMBA
Hello,
thanks in advance
vitor Galamba
Can you send me, please!
joaojero@gmail.com
question?
at the kits of orings, there are 8 small e 3 bigger, 1 bigger is for the pre-filter...and the others? what are the sizes of both?
thanks.
JJ
Old 11-05-2014, 02:52 PM
gazza1408's Avatar
c 180 56 plate
air in fuel lines
[ive just bought the retro kit 2024700193 with no instrutions ive seen that you have the instructions to fit it is there ant chance of e mailing them to me would be very gratefull if you could.my e mail address is garymwilliams@hotmail.co.uk thank you
Old 01-19-2016, 07:34 AM
cspcsp's Avatar
w202 250td
Hi all,
I'm having the same problem, could somebody please email me the instuctions?
Thanks,
Peter
Old 10-25-2019, 12:07 PM
Kurt Burger's Avatar
C250TD - Year 2000 - W202
Request for diesel line kit installation instructions
Emailed to you.
Kindly send me the kit installation instructions.
kurtburger69@gmail.com
Old 04-05-2020, 08:28 AM
Tonde's Avatar
1996 W202 C250 diesel
C250D
Hi
Can anybody send i have instructions to fit the retrofit kit.My C250D is having hard times on starting over night. My email address gwedetonderai@gmail.com thanks you guys.I will be waiting
Old 10-11-2021, 08:32 AM
o_j@landsvagsto's Avatar
MB C220D -1993
Instructions
Hi,
Can somebody please send me instructions for fitting this kit?
A2024700193
I have a C220D -1993
o_j@landsvagstorpet.se
Thanks.
Old 02-23-2022, 07:54 PM
geertc250's Avatar
w201 190d2.5 avantgarde, 190e 2.0, 190d 2.0 ,220ce,230ce,300ce,280e,300turbo diesel, 200te, sl300-24
retrofit instructios
Hi with geert, i am working on mmy fathers car c250 turbo diesel and a lot off air is in the lines from and to the filter. My father make an accident with the car 12 years ago at 18miles/h . He turned off the engine after the collaps on the other car. Now my brother and me are trying to run the engine again and repair the accident. At the moment the car crancks but not start. I loosen cylinder 1 the top hard line and nnothing comes out off the line when cranking the engine ,full throttle and no throlle. Is it the air in the lines or have you any idea? Kindley regards geert solie from Belgium
Quick Reply: Air in fuel lines - retrofit kit
