How much is your oil change?
Old Feb 9, 2009 | 12:56 AM
rondocap's Avatar
Mercedes S55 AMG
It seems like I've been spending around $100. I have a 2000 C280 sport, they usually use 5W40 Synthetic oil. (8 and a half qts I think.)
Does that sound right? Is there anywhere that I can get it done cheaper? Is 5w40 better than 0 or 10w40?
Old Feb 9, 2009 | 04:27 AM
Untertürkheim's Avatar
I normally pay $200 for the A service, which includes an oil change. They should use a 229.5 oil, which could be a 5w-40 (Liquimoly or Valvoline, the 0w-40 is Mobil). Just make sure it is 229.5 and not 229.51 or something else.
Old Feb 9, 2009 | 12:15 PM
w202305's Avatar
c230 kompressor 1999
all i pay for is the oil and filter i do all the work is not much but it takes time like 30min to do it right and clean the engine and stuff oil is no more than 60 and filter is 8
$68 in total for my oil change
Old Feb 9, 2009 | 01:11 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
well since my ********* have dropped i do it
Old Feb 9, 2009 | 03:49 PM
Z06EATER's Avatar
1997 C36AMG
oil change
for me will be around....
mobile 1 0W-40 (8Qts)=70 buks
2 cans of seafoam =20 buks (ten buks a can)
oil filter=8.99
deeep creep=9.99
about 120.00 or so.
hahaha
Old Feb 10, 2009 | 11:27 AM
$tallion's Avatar
97 C28
$90 i run mobile 1 15-50 my oils 8.00 a quart and good for 15,000 milesyet i change it every 5000 to keep it clean
Old Feb 10, 2009 | 03:17 PM
PhilfromPA's Avatar
300E 3.2
$75ish, filter, drain plug + 7 or 8 quarts of mobil 1
Old Mar 11, 2009 | 02:58 AM
thekopman's Avatar
04' W220 S280, 94' R129 SL500, 94' W124 220E, 02' W163 ML320
$100 for Mobil 0w-40 (8 litres), $10 for filter, $7 for labor (converted from THB)
TOTAL = 117 USD
Old Mar 11, 2009 | 08:20 PM
benz rider's Avatar
0w-40
7 quarts
$94 bucks.
Old Mar 16, 2009 | 07:50 PM
timmyj51's Avatar
Hundred bucks for an oil change!!! Yikes! Now I know how all
these mechanics can afford their rolexes.
The place I go to charges a little over twenty bucks to change the
oil in my C220 (5 quarts) and I supply the filter ($5.80). Castrol oil.
"Don't make your auto mechanic your heir" --Ben Franklin (slightly paraphrasaed)
Old Mar 18, 2009 | 07:07 PM
tex07's Avatar
2000 C230 sport
are you sure that you don't have to use synthetic in your car?
Old Mar 18, 2009 | 08:22 PM
timmyj51's Avatar
Don't use synthetic in my car ('95), but even if I did, would only cost another ten/fifteen bucks at the place I go to.
Old Mar 19, 2009 | 07:32 PM
rondocap's Avatar
Mercedes S55 AMG
My C280 uses up almost 9 quarts though, and it is synthetic. I get it done for $94 now at Valvoline with a coupon. Hey, I figure if I do it myself I'd only save a few bucks anyway, and they give you the records and know what they are doing more than I do.
Old Mar 20, 2009 | 12:25 PM
tex07's Avatar
2000 C230 sport
mercedes publishes the oil weights you are supposed to use, are you sure that you are doing this based on the proper user manual/publication?
Old Apr 8, 2009 | 05:22 AM
grigore's Avatar
c180 sport 1995
I use valvoline 10w40 durablend.A very reliable motor oil.30$/5 liters.
Old Apr 8, 2009 | 09:10 PM
timmyj51's Avatar
Costs me about twenty bucks (5 quarts Castrol GTX) plus five bucks for
OEM filter at the place I go to ('95 C220).
"Don't make your auto mechanic your heir."
--Ben Franklin (slightly paraphrased)
Old Apr 27, 2009 | 07:36 PM
ruzhkata's Avatar
Mercedes Benz C280
i got mine changed by a friend at the dealership
they charged me 14.99 for the oem filter. and the oil change is like $20 with the A service. Also for oil they charged me 75.00 USD because they didn't know my dad who did me a favor to go and get the car to the service because i was busy. But I fixed it and it's 50.00 USD. Used Mobil 1 Full synthetic 0w-40.
so u do the calculationss!
Old Apr 27, 2009 | 08:59 PM
timmyj51's Avatar
Gonna have to open a chain of quick-lube joints for MBs. With all you dudes forking over a hundred bucks an oil change I'll be able to retire when I'm 35.
Old Apr 28, 2009 | 09:41 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
I think factory trained mechanics have slightly more knowledge than a jiffy lube guy...
no hold on i do agree that dealers a alittle over priced but if you compare them (apples to apples) a good euro indy is at 85-100hr labor. But i do agree there should be specials on oil changes and maintence repairs diag is diffrent.
