Performance Drop by 20-30% What happaned
I realized that some times my C280 '97 Sport drops its power tremenuosly. Ex when i stop at the lights and start movinbg again i have to step on the gas like 50% down to get 40mph by the middle of the block (high way road block say 900ft in total ~~) At the same time on the same road when i feel that car has power i can press gas ~10-15% down and get to 40mph in about 1/4 of the block. Also what I notices is when I dont press on gass and i'm going los speed say 20mph I feel like cars brakes are in use and i'm loosing seed too fast.
Maybe some one have any ideas? Car has 83k miles on it so it seams not too much for mercedes. Oh yea, if I go max speed and max throttle for new sec (say from ligh to light) and then geting back to normal driving it seams that car gets much more power aftter wards. hmmm
Another note.. when car is not moving and engine is idle i get sort of vibration es[pessially when there is an decline toward passanger side. but when i release the brake and start moving the vibration goes to relative zero.
Finally I took OBD mesurments (maybe they would be handy for experts)
I hve results in both parked and driving positions of transmission (in both cases car was standing still) below is my data:
C280 OBD2:
At Idle, Pared position
Absolute Trotle Position: 2.7%
Engine RPM: 694 r/min
Speed: 0
Calculated Load: 15.7%
Timing Advance (Cyl. #1): -9.0 Degree
Intake Mainfold Presure: 33kPa
Flow rate (MAF Sensor): 3.33 g/s
Fuel System 1 Status: closed loop
Short Term Fuel Trim (Bank 1) -0.8%
Long Term Fuel Trim (Bank 1) +3.9%
Intake Air Temperature: 37 C
Coolant Temperature: 93 C
O2 Sensor 1, Bank 1: 0.195 V @ +1.6% s.t. fuel trim
O2 Sensor 2, Bank 1: 0.480 V
Driving Position (Summer Mode) standing still:
Absolute Throttle Position: 3.5%
Engine RPM: 599 r/min
Speed: 0
Load: 20.8%
Timing Advance (Cyl. 1) -8.5 Degree
Intake Mainfold Presure: 39 kPa
Air Flow Rate (MAF sesnor) 3.61 g/s
Fuel System 1 Status: Closed Loop
Thanks for help!
I dont remember old OBD2 readings... so maybe some one with share their load values on idle?My new mech told me to use differenet oil 10W-30 instead of 10W-40 that MB reccomends. can that be a problem?
Is the engine reving with low power, or are the RPMs staying low?
Just feels like i'm haveing 400 pounds in the trunk. Thing is tha its not the same, some times it works like i have 300 hp instead of my 145 hmm
Another thing is that engone wireing harnes that goes to (what thioese things called in English .. the once that prodie sparks for ignition) one of the wires seams to be either cut off and replaced (hopefully) or just cut off i think it should be relaced as OBD doesnt give any warnings so i assume all cylinders are fired up OK. I will have pix of that wire posted.
Whats a difference in oils
which part of oil means what. I know one is wiscosity and another um forgot.
How do i select oil? I dont want to "liquid" oil as it will leak. I have drain plug leakage .. i think all merces have that.
I don't know what it is, maybe the engine on these cars is just like that and not always consistent?
I can see bosch platinum plugs goes from $2 to $50 per each peace, but what is the difference? paying 50 x 6 = 300 for plugs alone is a bit too much for me on another hand 2x6=12 makes me cautious for low price
mass air sensor - where it is located?
they changed fuel pamp and spark plugs + filteres....
now it runs steady, but I think at the same time it runs steady as it has less power now hmm but is hard to say now i need more objective way of mesuring power...
I guess i will go to airstrip and do 0-60 test... i hope police wont see me there...
P.S. just watch out for cops if you're going to go past the speed limit. They hide everywhere!
but nost of the time i goe 20mpg in the city like and thats like terribel but at the same time i dont gas to much in the city line... no point geting fast and then wasting the brakes in 1 min on the nex light
PS: unfortunatly dont have supercharger... i'm not sure if i can get one in good condition for W202
