Transmission Fluid Change
Old 05-19-2009, 11:54 PM
TMAllison's Avatar
09' E320
TC drain plugs disappeared after 99 in most models that got the 722.6. Magnets did become standard sometime after 99 too I believe.
MB sells them, they sit in the corner of the pan next to the filter where the fluid is picked up.
Old 05-20-2009, 12:23 AM
xvvvz's Avatar
C230K
Magnet thoughts:
http://www.benzworld.org/forums/w202...an-magnet.html
Another tutorial:
http://www.benzworld.org/forums/w202...il-change.html
Old 10-24-2010, 03:48 PM
ohlord's Avatar
old thread
I know but for members searching around after1998 on models with no torque converter drain 722.6 5speed you flush out all the fluid via the trans cooling line
diy for the procedure on www.benzworld.org w210 diy section
you might as well get all of it out since mb now recommends 38000 mile fluid change on the 722.6 so called lifetime fluid (not)
valvoline maxlife nag1/722.6 fluid is spec and far less than mb or febi
autohausaz.com has the gasket and filter
I have dipsticks and magnet
replace the electrical connector that is a known issue of trans and tcu failures while your'e down there
Old 10-24-2010, 05:24 PM
Jovsky's Avatar
2000 C230 Kompressor Sport
Originally Posted by 99MBSport
http://www.peachparts.com/Wikka/Trans7226Fluid
This is the one I used when I did the change. The Torx head on the converter is a PITA. But if your going to do the fluid change do it all the way. God Luck.....
Just converted the link into an Adobe PDF file in case some of you need to keep a file of this. Hope this helps.
Old 05-27-2012, 08:21 PM
Daniel Crider's Avatar
96 C220
hey sorry to jump on your thread but i have a 96 c220 tht i recently changed the radiator in and i forgot to connect the trans line and some fluid was lost not alot, do you know wat fluid i shud uses and wer to put it in at
Old 06-24-2012, 06:17 PM
awbooth's Avatar
2013 Mercedes benz ML350 4Matic
How do you drain the fluid out of the converter?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Quick Reply: Transmission Fluid Change
