Has anyone installed 2007+ E500 rims (17") on a 96 C220
Subscribe
Apr 3, 2009 | 04:37 PM
And did it require any modifications (spacers, shorter bolts)?
and what is the max tire size I could could use.
These are the rims in question...
They currently have 245/45R17's mounted on all four
Thanks in advance for any assistance.
Reply 0
Apr 4, 2009 | 12:44 PM
I have a W202 with 235x35x19 rims&tyres on, plus it's the Sport model (Lower than the rest of the C class range) and its pretty much borderline. 245's are pretty wide, and being a 45 profile may make them bigger than mine overall - or pretty close. You should be ok. Can't you test them first?
Reply 0
Apr 4, 2009 | 07:58 PM
Are you on a stock suspenion setup? What are the dimensions of the wheels? 245 sounds kind of iffy but I'm sure others can help weigh in with more background info
Reply 0
Apr 6, 2009 | 05:19 PM
thanks for the responses. i ended up using universal 26mm bolts from Autozone and putting 205/50/17's in the front. might change the rears to 215/50/17's - but the 245's fit just fine now (just a tad wider looking than the fronts)
Reply 0
Apr 8, 2009 | 02:37 AM
245 is too wide for the front, max 235. Also the bolt size for the new e-class is m14, and w202 is m12 so the wheel will not bolt correctly and be dangerous.
Reply 0
Apr 8, 2009 | 04:57 PM
here they are installed (before and after)...
the bolts i used are 12mm x 1.5, 26mm thread length ball seat - sold at Autozone.
Reply 0
Apr 22, 2009 | 08:11 AM
how much you payed 17"???
Reply 0
Apr 22, 2009 | 04:25 PM
US $395.00
Reply 0
Explore
Apr 26, 2009 | 10:51 PM
looks great
i was thinking about putting rims from a newer model on my 96 c class
how do you go about ordering them from the dealer?
Reply 0
Apr 27, 2009 | 05:18 PM
not bad. looks pretty good. are you planning to drop it?
Reply 0
Apr 27, 2009 | 07:27 PM
rims look great.
I'd like to get a new set on mine, but i've just purchased tires, so unless i get a great deal.
but i've heard that when they swap rims on new models in dealerships they sell the swapped ones for very cheap!
Reply 0
Apr 27, 2009 | 10:46 PM
wheels look ok. But you gotta lower that thing
Reply 0
Apr 29, 2009 | 02:44 PM
That Looks great as it is
Reply 0
Subscribe
Currently Active Users (1)
