Intermittant missfire and drops to 5 cylinders
i had a loose injector wire and it did the same thing,
imo you changed way to many parts, the coils are twin spark so its normally either 2 cylinders working or not, and if you had just bought one coil and lead you could have changed them thru all 3 positions to see if that fixed the problem, maf sensor and air temp sensor wouldnt cause this.
to fire you need air and fuel, do you know what cylinder it is on? and are you sure its only running on 5 and not 4? if its 5 then itl be an injector wire you may be able to fix *carefully* without ruining all you wires,
if its 4 then itl be ignition wiring,
The plugs were supplied and fitted by the Service Agent - as were the sensors and the coil packs. Because this was quite an intermittent fault agent said was probably a coil breaking down and he had experienced this before.
The agents used their analyzer and according to them the changing of all these components was the "cure". I have lost faith now!!.
Thanks for the tip on injector connections - will check.
Also because the wiring loom does show some sign of deterioration around some of the insulation, will try that if injector connections do not cure.
god i wouldnt want to pay that dealer bill!
im in New Zealand to, pm me ur phone number if you want to talk,
like i said, if its not a ignition lead, then it has to be an injector wire.
if its down to 4 and not 5 it will be a coil wire.
if its 5 it will be a injector wire.
i have a few spare coil wires and injectors if its a blocked injector,
how mechanically minded are you?
i totally reckon it will be a degraded injector or ignition wire tho.
and if your confindent you may be able to replace this wire, before taking the plunge into a possibly $600+ wiring loom,
if you want to change the loom yourself i know where a write up is on how to do this yourself
from logan
This has totally repaired the occasional "stumble" I had when at idle and of course no more dropping down to the 5 cylinder mode. If anyone experiences the same type of problem strongly recommend checking injector plugs first.
