W202 Power Mast removal?
Hi All,
I have been searching high and low for instructions on how to pull out a factory installed power mast for my '97 C230
My mast broke off and I can't seem to get the cable out even after powering it on or off so I need to take out the power mast assembly.
I unscrewed the bottom bolt and the grounding strap from the unit, I also have the antenna mast out, by unscrewing the bolt that holds that on, but after that the power unit did not pull out after I gave it a few tugs. I'm afraid of breaking something. Is there another screw/bolt somewhere? Do I pull of the outer boot seal first or do I just keep pulling harder?
I came across this and some other threads, but it does not tell me how to get the mast out.
https://mbworld.org/forums/audio-ele...t-ii-w202.html
If someone can point me in the right direction to something with more details or a picture that would help immensely.
Cheers
Cliff
Cheers
Cliff
