Central Lock Issue
Old Dec 7, 2009 | 09:36 AM
rfoo's Avatar
1994 C220
Central Lock Issue
My rear driver side door doesn't lock whenever I press the lock button on my car. It will respond on my unlock command but won't with the lock.
Any idea what's causing this problem?
Old Dec 7, 2009 | 09:49 PM
AcousticplayerJ's Avatar
2000 c230 Kompressor
Maybe a vacuum leak? Perhaps you should disassemble the door and see what you can find.
Old Dec 8, 2009 | 02:32 AM
wampa's Avatar
E500 & ML500
It could be a bad door lock actuator. But I also recomend removing the door card to see what the problem is.
Old Dec 10, 2009 | 07:30 AM
rfoo's Avatar
1994 C220
Thanks fo the advice, I'll go do that first see what's going on, I'll update you guys.
Old Dec 10, 2009 | 11:05 AM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Please answer: Central locking is controlled via vacuum on these cars???
Old Dec 11, 2009 | 10:14 AM
rfoo's Avatar
1994 C220
yup, mine is controlled by a vacuum.
Old Dec 19, 2009 | 06:35 AM
maksi's Avatar
2020 GLC200 (X253) 1995 mb W202 C220, 2008 Mitsubishi Lancer Evolution, 2014 Ford Mustang 5.0
central locking issue
as far i know, it all operates via vacuum pump located in the right side boot. it's tucked underneath the sidings.
one thing i like this car, everything runs on vacuum. even the headlight adjuster. it gets its vacuum from the intake manifold to move the headlight angle up and down.
Old Dec 23, 2009 | 08:00 PM
maksi's Avatar
dude,
don't get me wrong, does the central lock have an actuator?
i thought it runs on vacuum?
Old Dec 24, 2009 | 02:05 AM
wampa's Avatar
E500 & ML500
Originally Posted by maksi
dude,
He mentioned that his rear driver side door was having problems. So I recommended that he check, the rear door Vacuum actuator on his W202.
Where did I say that the central lock has an actuator?
Old Dec 24, 2009 | 05:51 AM
maksi's Avatar
oh, sorry. wasn't fully myself from a night of partying lastnight.
mea culpa dude.
Old Dec 25, 2009 | 06:01 AM
rfoo's Avatar
1994 C220
hey maksi, which city are you from? I'm from Q.C. we should meet up sometimes.
Old Dec 25, 2009 | 09:13 PM
maksi's Avatar
oz?!
eastside dude!
cainta to be exact.
text ka. pm ko sa 'yo celphone number ko.
till next. . .
Old Jan 6, 2010 | 11:22 PM
rfoo's Avatar
1994 C220
Issue resolved.
Mechanic greased up my actuator and it worked fine. He said it just dried out.
