c180 gas door won't open !!
Old Dec 27, 2009 | 12:26 PM
Sonetuk1's Avatar
C180
Unhappy c180 gas door won't open !!
Am at work, very low on fuel, just got back from the gas station. The fuel lid just could not open. Pressed the cup in and out , unlocked/locked then unlock the car.
The lid remains locked. I have checked both fuse compartments boxes and can’t find any reference to the fuel lid.
Any ideas plse help
Old Dec 27, 2009 | 12:43 PM
Sonetuk1's Avatar
C180
Just it add, it's a c180 1997. Central locking works fine. The fuel lid just won't open.
Old Dec 27, 2009 | 05:44 PM
ohlord's Avatar
Your pse
might have a problem.
Try looking in the manual for the release of the lid via behind the panel covering the area behind the gas lid in the trunk.
Old Dec 28, 2009 | 10:47 PM
SamIam43vr's Avatar
2021 GLC43, 2014 G550, 2000 C280 Sport EX: 2019 C300 Convertible, 2010 GLK350, 2006 C55 AMG
pull on the red manual release behind the interior trunk trim. You'll have to pull the trim to the side to get to it.
Old Jan 4, 2010 | 07:23 AM
maksi's Avatar
2020 GLC200 (X253) 1995 mb W202 C220, 2008 Mitsubishi Lancer Evolution, 2014 Ford Mustang 5.0
i concur.
you need tear down the trim to get to it manually. maybe there you'll find what's wrong too.
Old Jan 10, 2010 | 02:16 PM
MarrsCars's Avatar
'99 c230 Kompressor
Others are right, but as to the cause, it's locked when the car is locked and vice/versa so probably a failure of the fuel door locking mechanism, which I assume is vacuum as well. If you can see the lock mechanism check for tubes that may have fallen off or a leak.
