C230 Kompressor problem
Old Jan 23, 2010 | 03:25 PM
ricoZg's Avatar
2000 CLK 320
My C230K has no power whatsoever. I'm basically running NA. It has no passing power, and when I floor it, the rpm's increase but the car doesn't go anywhere then gradually increases in speed.
I've cleaned the mass air flow sensor and even replaced it with a known good one (not new). I see the kompressor clutch spinning but don't really see or hear it disengage or engage, it's just spinning. I've hooked up an SDS and checked the actual values of the supercharger and at idle the clutch is off, and when rpm's are increased it stays off.
On startup, the bypass valve is open and when I increase the rpm's to >2000 it stays open. I'm not sure if the bypass valve stays open because the kompressor clutch is off or if it's supposed to close at a certain rpm. Either way it stays open.
I work at a Mercedes dealer, and some techs are saying the kompressor clutch is siezed, or it could be the bypass valve, or even the k40 relay. I'm not sure.
Here are the codes I pulled: P1236 Magnetic clutch of compressor: output stage is faulty; P0136 G3/6 (Right O2 sensor, after TWC [KAT]); P0170-022 Selfadaptation of mixture formation ME-SFI control module (N3/10): 'part load' for right bank of cylinders at limit value; P0170-023 Selfadaptation of mixture formation ME-SFI control module (N3/10): 'idle speed' for right bank of cylinders at limit value.
Sorry for the long post. I hope some diagnostic masters will chime in with any info.
PS. air filter has been changed less than a month ago and spark plugs have been changed too. I've owned the vehicle about 2 months now and that's all that has been done so far.
Thanks,
Mike G.
Old Jan 23, 2010 | 11:54 PM
xvvvz's Avatar
C230K
You could be chasing multiple problems. I am not an expert and you have the SDS, so you are ahead of me. Except for the P1236, I would have guessed you had an MAF problem and/or O2 sensor problem. I have to diagnose this right now too. If an MAF problem and/or O2 sensor problem gets real bad, the ECU will not let the kompressor engage but since you have the the P1236 error it sounds like you may have a mechanical kompressor error too.
Old Jan 25, 2010 | 11:35 PM
99komp202's Avatar
99 c230 kompressor
yes same thing happend to me the MAF went and the car went into basicaly a limp mode change the MAF if that dosent help then O2 sensor.
Old Jan 26, 2010 | 09:58 PM
ricoZg's Avatar
2000 CLK 320
So I should try the maf and o2 sensor?
So if those don't fix it then the P1236 code basically means I need a new kompressor clutch, right?
Mike G.
Old Jan 28, 2010 | 04:24 PM
ricoZg's Avatar
2000 CLK 320
Update: swapped k40 relay with a known good one, no change.
I'm pretty sure I'm going to need a new kompressor clutch. Or just get a rebuilt kompressor with clutch.
Mike G.
Old Jul 5, 2011 | 07:52 PM
Jabbster's Avatar
2000 C230
Mike G.
Mike,
Same problem here, did you try replacing the supercharger clutch (coupling) ?
Old Jul 5, 2011 | 08:57 PM
ricoZg's Avatar
2000 CLK 320
I replaced the kompressor clutch with a new one. I ended up selling the C230k last October, but it turns out in addition to the air mass sensor it also needed a new trans control unit.
Old Jul 6, 2011 | 01:48 PM
Russell Ormerod's Avatar
not a merc
Hi Rico, I wonder if you could help me out?
I am looking for the variant coding number of a C230K W202 Auto
For the engine ECU ME2.0
If you have a car like that in your shop could you check it for me please/
Would really appreciate it. I have a unit i am trying to code.
Old Jul 6, 2011 | 08:45 PM
Jabbster's Avatar
2000 C230
So was the Kompressor clutch part of the problem, or did you replace it without need ing too?
Thanks!
Old Jul 6, 2011 | 09:02 PM
ricoZg's Avatar
2000 CLK 320
I'll see what I can do about the coding, we've been pretty busy lately.
The clutch was definitely part of the problem. It was seized and made a loud noise. After replacing it, no noise and a little more power.
Old Jul 7, 2011 | 07:16 AM
not a merc
[quote=ricoZg;4745179]I'll see what I can do about the coding, we've been pretty busy lately.
Thank You Rico
Old Jun 9, 2013 | 02:09 PM
henry.mouawad's Avatar
CLK 1999 230K
Hi
I have a CLK W208 230 Kompressor 1999
the kompressor clutch will not engage
after taking it to the mechanics he informed me that the clutch need to be changed and no parts available so we should change the whole kompressor
BAS/ASR light is on
a defective fuse on the k40 relay (Fuse number 3 15A)
when changing it the light goes off
but when the RPM reaches 2000 the fuse will fries and the light comes on again
plz advise if someone already had this problem?
and how to solve it should i change the kompressor or the K40 relay ?
i removed the relay and the soldering are not torn
Old Jun 11, 2013 | 10:09 AM
CLK 1999 230K
does anyone knows a solution please?
Old Jun 16, 2013 | 08:18 PM
cashbrownz's Avatar
2000 c230 kompressor
Were you able to remove the entire K40 assembly and inspect the board itself or did you just check the plug in relay on top? Search for k40 relay fix on youtube for instructions on checking the board itself.
