W202 Mirror Fix
I've had some challenges with a broken passenger side mirror. Somehow, the hook thing that holds the mirror assembly in place broke. Replacing it meant getting an entire mirror assembly (less the cover). That was a bit too pricey (> $200). I figured there had to be a way to fix it. The spring they use in these mirrors is ridiculously strong (would probably work on a suspension somewhere), anyway, my first attempt was to epoxy the hook back on. Didn't think it would work, and it didn't. It did result in the area getting filled with epoxy. I then tried screwing an eye hook into the epoxy. That held for about a month, but the eye hook pulled out of the epoxy. My last fix, and I am confident this will hold is to basically bolt an eye hook through the thing, using a couple of fender washers for support. Here are some pics. A couple of bucks for parts and a couple hours and this should be stronger that original.
I had to grind off the washers so the rubber would fit back through.
Back side picture. No problems with clearance after it is installed.
Assembled, not sure what possessed them to use the monster spring on these mirrors.
I'm interested in your fix for the hinge. You are speaking of the brass-colored hinge in Hookster's pictures, correct? Mine also broke near the top end when someone clipped the mirror in a parking lot. I thought of doing the same sort of "drill-&-nail" fix, but it will take a very small drill it seems. What size drill did you use? You used a Dremel perhaps? Did you do the drilling while the mirror was on the car, or off? Any other suggestions? Thanks.
Hookster, nice job on your fix. You're right about that massive spring. When my hinge broke, I had to lessen the tension with a loop of coathanger wire between the spring and its attachment site, so that my mirror would sit relatively straight on the car. Hopefully, I can now do the drill&nail fix for my hinge problem.
RockAuto has a replacement glass for $7.52, but I'm not sure how I would attach it to the backing plate. Has anyone replaced the mirror only?
Anyone doing it for the first time should look it up on YouTube, to be sure they understand how to release the mirror cover properly. If you don't do it properly, there is a chance the cover won't snap back on correctly. I am speaking from experience. The rule is, if all else fails, read the instructions, or Don't force it, use a bigger hammer.
And he's right, for those of you who want to fix your busted side-view mirrors, that spring that holds the mirror to the body is STRONG! This is a great fix for those of you who don't want to go to a junk yard and pull your own replacement mirror.
I pulled a working mirror from a local Pick-N-Pull yard and replaced the entire internal package, which was much easier and faster than trying to swap out all the moving parts.
Do it. So much better having a properly working mirror.
