Engine Idle Problem
Old Mar 15, 2010 | 09:22 AM
bigtex22's Avatar
1995 C280
Engine Idle Problem
New to community guys, quick problem I have with my 1995 C280.
When i cold start(sometimes just starting period) the car the engine rev's up kinda high, then when it idles the rpm's drop down really low and after say 30 seconds the engine dies. Sometimes it requires me to start the car 3-4 times before it starts idling correctly. The engine dies sometimes in reverse if its not warmed up. Another thing I'd like to note is that the engine has never died at a stop light idling, or whenever the car is in drive. Its always just whenever I start the car and try to warm up the engine.
Any help would be greatly appreciated.
Old Mar 15, 2010 | 10:03 AM
wesrick's Avatar
1998 C280
When did the problem start? All of a sudden or progressively?
Is your check engine light on?
How many miles on the car?
What I think it could be:
MAF sensor: When did you last replace the MAF sensor?
Intake tube: Is the intake tube (the rubber tube that uses metal snaps to connect the airbox to the intake, does it have any breaks or leaks? Have you rechecked to make sure that it's connected correctly?
Old Mar 15, 2010 | 01:49 PM
bigtex22's Avatar
1995 C280
This problem has been existant for over a year. Its been like that since I bought the car and previous owner has the same problem. Car has 280 K miles on it. Rebuilt engine and tranny at 200K. Check engine light is not on, although I have seen it on before in the past year it doesn't stay on though. Anyways I will check MAS today in a bit, I don't know when the last time it was replaced. Thanks for the quick response.
Old Mar 16, 2010 | 09:24 AM
wesrick's Avatar
1998 C280
Noted
If/When you solve it, please post the solution...
Old Mar 21, 2010 | 12:34 AM
SZMB's Avatar
2004 E500 CLK320
It could be related to the idle control valve, but not for sure since it idles fine when the car is in drive gear. I assume you have done all the basic maintenance: air filter, fuel filter, spark plugs.
Old Mar 22, 2010 | 12:28 AM
bigtex22's Avatar
1995 C280
ya just got back in town. spark plugs are new. As for the MAS, and cleaning I'm going to do that and see if it fixes the problem . I will let you know asap.
