Being able to turn and still tuck tire.
Old May 13, 2010 | 10:30 PM
Magnum126's Avatar
W203 C320
I have my C230 lowered with Koni springs and shocks with #1 pads all around. The wheels are 19x8.5+31mm in the front. I am having the hub pad milled down so it will be a +35mm offset. I have a fender roller and will be rolling the fenders. Right now I can't even turn the wheel more than 1/8 of a turn before it rubs on the fender. Is the offset change and rolled fenders going to be enough to get enough steering angle to drive or am I going to need to lift it some. Any suggestion are welcome. I would love to keep it at this height. Rhyi and Ruzhkata how do you roll so low?
Old May 18, 2010 | 03:51 AM
wichipong's Avatar
95 w202 C220
you could switch back to thicker pads and cutting coils..
if ever you did that, im still looking for a pair of 5mm (#1) pads..
Old May 18, 2010 | 01:20 PM
Magnum126's Avatar
W203 C320
The #1 pads are less than $8 each from the dealer.
Old May 18, 2010 | 08:43 PM
rfoo's Avatar
1994 C220
I suggest put #4 pads to lift the car, that way you don't have to do a fender roll.
Old May 19, 2010 | 03:56 PM
YNVDIZW124's Avatar
lots of cars
Make sure you use a heat gun when rolling the fenders. I would pull them out a little too.. I suggest you just get bigger pads on the front and rear. Something like #2 front and #4 rear.
I'm running #1 pads on the front and stock pads on the rear.
Old May 20, 2010 | 08:00 AM
DRBC43AMG's Avatar
Sorry, but looks like someone stole your springs..... Too low IMO
Old May 20, 2010 | 05:59 PM
YNVDIZW124's Avatar
lots of cars
Naw, that's a pretty good stance. I would say 5mm higher and spacers...
Old May 30, 2010 | 08:10 PM
whitm88's Avatar
2000 C230 Kompressor
It's a Mercedes, not a Honda or Chevrolet. I promise I'm not trying to be rude. I just think that Mercedes does a wonderful job with the height of their cars.
