Will 235/45/17 tires fit a C280?
Old Apr 6, 2003 | 07:33 PM
vjd3's Avatar
Tire Rack recommends 225s ... is 235 too wide? It's a 17" AMG rim.
Vic
99 C280
Old Apr 6, 2003 | 09:01 PM
tpliquid's Avatar
too poor now
no lowered will work. lowered will need roll fender and cut some plastic.
Old Apr 6, 2003 | 09:09 PM
vjd3's Avatar
Thanks ... car is completely stock. Is there an advantage to the 235 size over the 225? They are just a little wider, yes?
Vic
99 C280
Old Apr 6, 2003 | 09:11 PM
tpliquid's Avatar
too poor now
10mm wider
Old Apr 6, 2003 | 11:43 PM
DougandhisC280's Avatar
2008 SLK-280
You will get hardly noticable better handling. You will lose wet traction (hardly) and lose gas mileage.
Old Apr 7, 2003 | 01:08 AM
vjd3's Avatar
just perusing the accessories catalog ... which for the 7.5X17 size says "requires body modification and fender rolling" for C Class. True? Or will they bolt right on there?
Vic
99 C280
Old Apr 7, 2003 | 01:14 AM
tpliquid's Avatar
too poor now
if u do decide to do the HR cup kit. or cut springs u will need to do fender rolling. if the tires are tucked. then u need to roll fender. if no tuckl u do not need to roll fender.
the 17x7.5 ET35? or was it 30? will fit. the stock C43 or C36 rims will fit or the SLK
Old Apr 7, 2003 | 06:00 AM
vjd3's Avatar
The rims are stock CLK 430 rims ...
Thanks,
Vic
99 C280
Old Apr 7, 2003 | 04:15 PM
tpliquid's Avatar
too poor now
no problem then. no rubbing
Old Apr 7, 2003 | 05:28 PM
vjd3's Avatar
Thanks for the assistance. The seller agreed to put 225 Dunlops on for me instead of the 235 Michelins, so it should be perfect now.
Vic
99 C280
Old Apr 7, 2003 | 07:28 PM
2008 SLK-280
Except for the fact that you're getting Dunlops instead of Michelins.
Old Apr 7, 2003 | 10:56 PM
vjd3's Avatar
Well, hell ... $895 for a mint set of 17" AMG's with 85 percent tread on the Dunlops, who's complaining? :-)
Actually, the C280 is my bad-weather bad-traffic driver; I have a 95 Carrera 4 with P-Zero's to run hard.
Vic
99 C280
Old Apr 8, 2003 | 04:33 PM
2008 SLK-280
must be nice
Old Apr 8, 2003 | 04:44 PM
tpliquid's Avatar
too poor now
good deal. i sholw sellm y AMG's perfect condition with 100% tires for that much. iwa sgonna sell for cheaper thou
