P0446 AND stalling out.
Old Sep 18, 2010 | 08:10 AM
C230Ak's Avatar
2012 C63 (P31)/2006 CLK350 Coupe
Yo, I tried posting this questions in a few relevant threads but to no avail. They must have been to old to be noticed. I am trying a new thread in the hopes that it will catch the eye of someone who can shed some light on my situation.
I had my MIL come on and the engine rpm would bog to below 500 or so and the car shudders when I come to a stop and sometimes it even shuts down completely. I hit it with a scanner and the only code that it showed was P0446: EVAP vent control circuit. None of the other threads mentioning P0446 mentioned any low speed bogging or stalling...
My real question is, should P0446 or any related problems cause the engine to stall. I believe it to be some sort of vacuum leak because I recreated the shaking/bogging by removing the purge valve - throttle body hose from the throttle body creating a massive vacuum leak. I also checked the purge valve itself by removing and activating it and it seems to work just fine, Click. Click. I just have not checked the canister vent valve yet because it's much harder to access.
Could a faulty canister vent valve create any drive-ability issues at all???
Old Sep 20, 2010 | 03:39 PM
C230Ak's Avatar
So is no one replying because they don't know or am I being unanimously ignored?...
Old Sep 20, 2010 | 04:55 PM
ohlord's Avatar
you NEED
to check the canister vent and wiring .
Do you make a habit of topping off the fuel tank?
Old Sep 20, 2010 | 06:46 PM
C230Ak's Avatar
Nope, the pump stops and I'm done. All I do is turn the pump handle upside down and jiggle it to not drip fuel when I put it back. I've also noticed that canister vent valves are tough to find. Even on autohauz it was an obscure part.
Old Sep 22, 2010 | 07:08 AM
C230Ak's Avatar
Vent
So I checked the vent valve on the canister and that's fine. For a P0446, does that just leave a faulty CPU as the cause?
Old Sep 22, 2010 | 12:15 PM
ohlord's Avatar
If the vent is
fine then the solenoid is probably done in
that's why the 0446 circuit fault.
Old Sep 22, 2010 | 05:01 PM
C230Ak's Avatar
Solenoid vent
Aren't the solenoid and vent valve the same. I removed the whole unit from the canister and was able to activate the solenoid. It clicks and seals off the vent. Same thing with the purge up front. They're both tip top.
