Only keys locked in trunk
Old Oct 24, 2010 | 08:25 AM
pauldyma's Avatar
1999 C230 Kompressor
Question Only keys locked in trunk
Hello All,
I have a 1999 C230 kompressor.
My only set of keys are locked in the trunk both smart (electronic) and mechanical (thin metal).
Is there any way to open the trunk or back set manually so I can retrieve the keys?
Thanks you for any help you can offer.
Paul
Old Oct 24, 2010 | 07:44 PM
Jovsky's Avatar
2000 C230 Kompressor Sport
Contact AAA and have them open your car for you if you are a member of AAA.
Old Oct 25, 2010 | 01:10 PM
Capt's Avatar
2000 C280 Sport
Paul
If you can get in the cabin why not just press the trunk release switch? If your battery is dead you can get power to the system from setting up booster cables in the engine bay (even though the battery is in the trunk). There is a write up in here somewhere about how do do this.
Good luck.
Edit: http://www.benzworld.org/forums/w202...runk-help.html
Old Oct 31, 2010 | 02:00 PM
rodwell.2009's Avatar
c class
get a car battery connect jump leads positive to live on alternator and earth to ground boot release should work
Paul[/quote]
