mirror and pwr window problems
Old Aug 5, 2011 | 01:33 PM
grinder143's Avatar
1999 c230
i am having an issue on my 99 c230. front windows wont roll down at the same time the pwr mirrors quit working , however the rear windows do roll down. i checked the fuses in both the engine and trunk locations. I am not sure if it is relitive but bas light came on after the breaks were replace and the cruise control stop about that same time. any ideas
Old Aug 6, 2011 | 10:39 AM
Russell Ormerod's Avatar
not a merc
You need to scan test to see if your body bus is running without faults. as a test try disconnecting the rear door modules and see if the front starts to work again,
regarding th BAS lamp that will be a seperate issue.
Old Sep 25, 2011 | 04:35 PM
Haddara's Avatar
97- C180
Hi, I have a weird problem! I have unplugged and replugged some fuses for a checkup. Since then, my front electric windows (rears are manual) won't operate at all unless any door is open!!! The windows work perfectly when a door is open, stop on the spot you close a door.
Any suggestions? I have tried the window resetting thing and didn't work, specially that the door has to be open while doing it too. I have also changed the fuse, unplug the battery, etc.. and didn't help.
Any ideas?
