1999 C280 Odometer Display Problem
Although I've looked through the forum I'm really not seeing much on the subject but I did find this https://mbworld.org/forums/c-class-w...ease-help.html
"shimming the ribbon cable connector that connects to the back to the instrument cluster at the odometer?"
I have no idea how one would do this but it seems the be the only info I can find. Anyone have any other ideas?
Much thanks...
I had to buy the cluster puller tool (Part # 140 589 02 33 00) to pull out the cluster. At the back of the cluster are the bulb(s) that you need to replace. In my case, it was the (Beige Base - 12v 1.5w Part # N 910 141 00 00 00) and viola! the odometer illuminated again.
Check this thread for added info: https://mbworld.org/forums/c-class-w...er-dimmed.html
