Subwoofer installation/wire running
Old Jun 8, 2003 | 03:45 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Hi all,
I need some help with running amp wires to the front of the car to the deck. I'm installing sub's myself and I know I can run the wires along the side of the car, underneathe the plastic part that runs parallel with the door, but how I can I get the wire to that part from the trunk and to behind the deck. Any help would be good! Thanks.
-Greg
Old Jun 8, 2003 | 04:57 PM
DougandhisC280's Avatar
2008 SLK-280
Why can't you go along the side?
Old Jun 8, 2003 | 05:01 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
along the side meaning the door sills part? That is no problem, it's just getting the amp cable underneathe the dash, after I reach the end of the side up front, then behind the deck so that I can wire it up.
Where do I go through underneathe the dash cuz I don't want to F up any electronic stuff. Thanks Doug.
Old Jun 8, 2003 | 06:22 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
If you're in the plastic in the door sills, just follow that. The gutter goes from the back of the front door sill across the floor in front of the seat. Then it runs up towards the shifter and then forward under the radio.
All you had to do was look!
-s-
Old Jun 8, 2003 | 06:51 PM
2008 SLK-280
Thanks Doug
Nope, thank Scorchie.
Old Jun 8, 2003 | 07:27 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Thanks Scorchie...just ran the wires. Gonna hook up the rest tomorrow!
Old Jun 8, 2003 | 09:12 PM
2008 SLK-280
Old Jun 9, 2003 | 09:32 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
question on grounding the cap and amp. Theres a bolt that holds the battery (at the bottom), which I think is attached to the chassis. Can i use that to ground my cap and amp?
Has anyone installed subwoofers in their car and know how to connect the amp to cap to battery? Any help would be greatly appreciated.
Old Jun 9, 2003 | 09:45 PM
2008 SLK-280
That should be a good ground.
Old Jun 10, 2003 | 02:21 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
shouldn't the ground be as close to the item u'r grounding as possible?
Old Jun 10, 2003 | 11:18 AM
2008 SLK-280
That bolt isn't far away, it's right there in the trunk.
Old Jun 10, 2003 | 08:21 PM
scorchie's Avatar
There's a real ground point in the trunk behind the left interior panel. You may want to consider using that. Using a mechanical hold down as an electrical connection probably isn't that great of an idea.
-s-
Old Jun 10, 2003 | 11:54 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I've finished hooking up the system I used the exisiting negative battery terminal as the ground and should be fine. Anyone think this is a bad idea because I could not find any other place to drill and don't want to risk puncturing anything.
I'll post some pics tomorrow.
Old Jun 11, 2003 | 12:54 AM
2008 SLK-280
As long as it's a good unpainted sturdy ground it should be fine.
Old Jun 11, 2003 | 12:56 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
I just hooked it up to the negative terminal (at the end of the bolt) as the ground...i asked some people and they said it should be fine?
Old Jun 11, 2003 | 05:15 PM
scorchie's Avatar
Should be fine.. just an extra cable running from the battery.
-s-
Old Jun 17, 2003 | 11:31 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Got the pics finally.
Attached Thumbnails Subwoofer installation/wire running-dsc00749-web-.jpg
Old Jun 17, 2003 | 11:32 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
another...
Attached Thumbnails Subwoofer installation/wire running-dsc00751-web-.jpg
Old Jun 17, 2003 | 11:33 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
last one...this one of deck.
Attached Thumbnails Subwoofer installation/wire running-dsc00753-web-.jpg
Old Jun 24, 2003 | 01:07 PM
aKaKonG Ric3r's Avatar
Gary-Fisher by BenZ
F&F subs suck a$$!!!! you need EKS subs, hooked up onto the sides of a nice rice-rocket fisher, *****, if you want somethin fast, you betta b smart and go fo the gerry fisher, aka ric3-fish-rocket, you'll whoop anyone's a$$ with that, bumpin along the streets wit dual 10" subs, and ridin on 24"s, thats life.
Old Jun 24, 2003 | 01:09 PM
2~s0L~t's Avatar
1968 cadillac coupe deville calais hardtop
it'd be nice...
if that made some sense...
Old Jun 24, 2003 | 01:24 PM
2008 SLK-280
aKaKonG Ric3r:
Attached Thumbnails Subwoofer installation/wire running-h9.gif
Old Jun 24, 2003 | 01:27 PM
Gary-Fisher by BenZ
sorry buddy... im not american.. i guess crackas these days dun understand what it comes to when someone states 'ric3r' especially with a rice rocket fisher.. your whack
..nice try though ^.^
Old Jun 24, 2003 | 01:30 PM
2008 SLK-280
speechless......
Old Jun 24, 2003 | 01:33 PM
Gary-Fisher by BenZ
ooh, you are soo damn cool.. with your c280 and all.. you're so rich that you can afford a C CLASS! omg! wow.. you're just a poser who wants to be able to afford a quality benz, so because you have no money to get an S class or anythin, you go for the baby s, the C.. loser! you get ~190 bhp in that thing? woot!! im sure you'll haul a$$, i'd take you on anyday, no competition, my fisher would leave you in the dust, no.. it'd leave you in da mud, foo
damn wannabe's.. you will never be able to become a real benz owner, get rid of your c class and go hop up a kia instead, it'll look better in your life
