Front spring removal?
Old May 3, 2012 | 09:38 PM
Seattle_202's Avatar
1997 C230
I'm going to lower the car in a few days and had a few questions about how to remove the front springs. I've done the "search" and those who has done it required the Mercedes type spring compressor. My question is can I do this with the floor jack. As in, use the jack to compress it, then release the pressure slowly to release it? has anyone gone this route? How safe is it? I know there is some risk involved but just how risky is too risky? I plan on R&R (remove and reinstall) till I get the height I want. So it might take a few days at the most. Oh one more thing, front camber kit? I know there's a few on here who are practically sitting on the ground. How did you go about fixing the camber? Yes, KMAC I know but other options please. Input and advice is greatly appreciated. Thanks.
Old May 5, 2012 | 11:14 PM
MASTERBENZ's Avatar
Mercedes-Benzes: 2005 ML500, 2002 E320 4-Matic, 1993 300E, 1994 E320, AND 1999 C230 KOMPRESSOR
Please DO NOT use a jack! Use the Mercedes-Benz spring compressor! Safety first, and it's not worth the aggravation. I've done plenty of these springs, and it has A LOT of tension and pressure even when I use the Mercedes-Benz spring compressor!
Old May 18, 2012 | 01:12 AM
ronniei30's Avatar
1994 c220
where can i get a mercedes spring compressor? i need to do my coil springs too.
