car starts for a second then dies??
Old Aug 25, 2012 | 03:56 AM
siyamak's Avatar
Merc C200 1997
yesterday while driving (merc c200 1997), i accelerated to overtake another car, halfway my car just went off!! the car would start and then die in a second .. tried several times but no use .. even accelerating wouldnt stop it from turning off ..
this morning I went back to the car to check it up and it started .. i drove it for few hundred meters to home and when I stopped it went off .. now as soon as the car starts, I have to accelerate to keep it on otherwise it would just go off .. initially I thought my fuel pump was dead but today Im confused and not sure whats causing it .. any help would be appreciated
Old Sep 4, 2012 | 02:20 AM
PelicanParts.com's Avatar
SPONSOR
Answer
The crank position sensor and/or fuel pump relay may have issues as they warm up.
roy@pelicanparts.com
Old Sep 10, 2012 | 08:14 AM
kalindwana's Avatar
mercedes benz c180
hie , cn sm1 help me , i hv a situation here , i nid a circuit diagram 4 a 202 , am nt getting power 2 e motor
Old Sep 13, 2012 | 07:45 AM
maksi's Avatar
2020 GLC200 (X253) 1995 mb W202 C220, 2008 Mitsubishi Lancer Evolution, 2014 Ford Mustang 5.0
had the similar problem before had to replace fuel pump and filter at first but no luck.
try to have it diagnosed thru the dealer's diagnostic computer. chances are, your slide idle control actuator is already fried. just a hunch; given the limited description you enumerated above.
this is what it looks like (i also indicated the part number as file name):
Attached Thumbnails car starts for a second then dies??-throttle-housing-0011410225.jpg
Old Sep 13, 2012 | 07:48 AM
maksi's Avatar
have it diagnosed using the computer, it will save you alot of headaches and moola before doing your own DIY.
and next time try to write legibly, not alot of us read and speak text lingo.
Old Sep 13, 2012 | 09:23 AM
kalindwana's Avatar
mercedes benz c180
thank you so much , anyway am sorry for my language ....
For my problem , i ended up solving the problem , i hd to find out that the actuator motor hd no power supply . The reason wz a faulty high voltage supply .... I replaced it and the vehicle is nw ok
