engine vibrates in Drive
Old Oct 18, 2012 | 11:51 PM
kendal's Avatar
1997 c class
When i start my car form cold it vibrates when i engage in Drive (Automatic transmission). It takes a while to engage second gear. When i step on it,it raves up and doesnt engage second gear.
Old Oct 19, 2012 | 04:47 AM
johnng117's Avatar
2002 C32 AMG
I guess its time to change the engine mounts.
Old Oct 20, 2012 | 12:18 PM
Vander's Avatar
2002 E55 AMG, 06 C55 AMG, 72 350SL
Yeah, sounds like engine mounts. If Check engine light is on maybe a tune-up.
Old Nov 1, 2012 | 09:30 PM
cjennjr's Avatar
2005 SL500
My 99 C230K started running rough in drive, but smooth in all other gears. I will try and clean the MAF sensor first and see if that's the culprit. If not, plug change is next. If none of the above works, I will buy a new sensor.
Old Nov 3, 2012 | 11:58 AM
ptcruiser's Avatar
C230
Curious as to why engine mounts may be the answer. I have the same problem when I am at a stop sign for example. In drive, it vibrates, but as soon as I accelerate from the stop, it's fine, and shifts perfectly.
Mounts seem fairly inexpensive. I was thinking it may be the idle speed?
Old Nov 4, 2012 | 12:41 AM
cjennjr's Avatar
2005 SL500
I totally agree. It would be apparent that if the mounts were bad, the engine would vibrate in ALL gears, not just in Drive.
Old Nov 4, 2012 | 03:38 PM
pinkfloydfan810's Avatar
97 C230
Trans mount. Try that first. It's a DIY.
Old Nov 5, 2012 | 09:33 AM
ptcruiser's Avatar
C230
As the mounts are inexpensive, doing them all at the same time is probably common sense. If the engine mounts need replacing, I would imagine the trans is just about ready as well.
Old Nov 5, 2012 | 01:13 PM
97 C230
Do the trans mount, motor mounts. Go with Lemfoerder for engine mounts, I don't know who makes a trans mount but just go with MB. It's not a bad replacement on the 202. Just get a breaker bar. And there's a video on youtube for engine mounts.
