Phone sound at startup
Its a 2000 280 sport.
-s-
If you pull the fuse, you'll take out a few other things. I believe that the sound comes from the speaker on the right side of the front passenger's footwell. Just disable the speaker as it has nothing to do with the radio audio system, just tele-aid. I think that the purpose of the sound is a self-diag test of the tele-aid system that lets you know it is functioning.
-s-
Thanks JAM, I appreciate the help. I did a search in the W202 forum like scorchie insisted and nothing came up. But in any case, thanks scorchie for the useless criticism, that really helped me out a lot!
If you think it's useless to try and listen when someone is offering help, then that's fine... enjoy your car.
Anyhow, to solve your problem, you need to remove the lining in your trunk. On the right side. Then disconnect the phone modules there. There are two lines going to it, unplug the fibre optic line to take it out of the loop, and the other is a power/mic/speaker connector, held in by two thumb screws. Remove that as well.
-s-
(I am beginning to like the upgraded VBB with IGNORE function... although the database seems to be taking a hit every now and then...)
