NO HEAT HELP PLEASE
Old Jan 20, 2016 | 08:16 AM
leviohanenye's Avatar
1994 Mercedes-Benz C280
NO HEAT HELP PLEASE
Hello all. I know this should be in the W202 section (I posted it there) but this is urgent. I have no heat and my mom must drive the car tomorrow with a nephew (he's 2). I need to know if there's anything that I can do t this point to get the heat back on. There is just no air coming from the vents to push the heat out, as i can feel the heat coming from the vents.....
this is a link to the video. the clicking sound is what happens when I press the heat button on and the whining sound accompanies it.
Thanks in advance!
Old Jan 20, 2016 | 11:36 AM
Originally Posted by Plutoe
If you are correct that you can feel the heat yet the fan is not engaging to blow the hot air into the cabin------therefore it sounds like you need a new fan-------and that can't be done in less than 24 hours unless you visit the dealer!!
PS----have you checked all the fuses-----bla bla
I checked the fuses, is there a relay for it? Also, is there a possibility that it is the fan brushes, or regulator or does it sound like the fan?
Old Jan 21, 2016 | 08:47 AM
Okay, I went to the local Indy, he said that the blower motor and the blower regulator have gone. Will these fit my vehicle? its a 1994 C280 BASE 2.8. It says they wont on eBay, but i feel as though they probably will. Also, what other cars from this era share this same type of part with my car? Thanks in advance!
http://www.ebay.com/itm/291614948530
http://www.ebay.com/itm/361458904037
Old Jan 21, 2016 | 11:14 AM
WDBHA28EXRF090732 1994 c280 (comes up as 1995 sometimes) so im not sure if its a 94 or 95.
