c200 1994 is it HMF or PMS
please can you kindly visit this link !! and see the spec of the scanner !!
and one more thing russel this person had successfully connected a cheap obd2 elm327 which i also have , and he was success
http://www.hfmscan.com/en/mercedes_diagnose_ELM327.html
thanks
any other scanner you think that could work ?
ill try and let you know !! thanks you friend !! and please check your email !! i
1. your HFM ECU 2.0 Japan.
2. your ECU have not immo.
3. ELM327 will not read your engine.
4. Use VAG COM 409.1 (cost 5$ on www.ebay.com) or any USB KKL for read your engine with hfmscan.
5. On my site is proposed modified ELM327, which supports only the old Mercedes and nothing else...
Mike.
PS: https://www.youtube.com/results?search_query=hfmscan
Mike.
and Russell is also helping me alot with this problem !! and i really appreciate for both of yours tips and help specially your time !!
so as far as i have diagnosed i feel that it lean !! backfire at intake as russel mentioned !! so until the scan comes can you roughly tel what areas are responsible for this particular problem !! with experience of both of you
i replaced the fuel pressure regulator from the company !! 250$ :/
thank you !! guys !!
the HFM ignition retard knob is at 7 in mine !! i have an engine miss now !!! the mixture problem is solved as i feel because the spark plug are whitish color !!
Vvt should have 12v on one of the terminals with ignition on at all times.
The ground is only there when the ecu decides to vary the timing.
Forget about vvt for now it will not cause a misfire. Misfired occur more easily with a lean mixture.. when does it misfire? At idle all the time or only under load? Next step determine what cyl is the misfire on... swop the suppressor and or coil to a good cylinder to see if misfire shifts to another cyl... you can pin point your problem that way. Leave o2 disconnected for now.
regulator price 30-50$HfmScan through this adapter reads any 104 and 111 (HFM \ PMS) at once and do not need to buy anything more.
plus engine diagnostics with the phone\tablet...
now my main problems are
engine miss
wont rev more than 4300 rpm
poor throttle response !!
thank you
regulator price 30-50$in this case it is better to buy ELM327 WIFI\USB for mercedes.
and yes the fuel pressure regulator i replace i bought it from the mercedes company !! it was around 25000 LKR from my currency which is equal to 250$ because the after market parts we have in Srilanka is not that much quality !! so i wanted not to have loop holes again in my new replacements so i cant diagnose it !!
thank you for the reply appreciate it !!
so "my adapter" can read the old Mercedes and can not read modern car (OBD2)
