i have had a new ecu fitted to my 1994 C200 and my coolant temp gauge does not work c
Old Jun 11, 2017 | 04:50 AM
andytaxi's Avatar
1994 C200 w202
i have had a new ecu fitted to my 1994 C200 and my coolant gauge has stopped working could this be related to the new ecu
Old Jun 12, 2017 | 02:50 PM
andytaxi's Avatar
1994 C200 w202
hi pal after changing the coolant sensor, i traced the wire back and it goes into a tapped loom that seams to end at the ecu, i didnt try to trace any more as its a new ecu and didnt want to risk damage
Old Jun 13, 2017 | 10:53 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W202 forum...
Old Jun 13, 2017 | 01:28 PM
Russell Ormerod's Avatar
not a merc
There are a few variants. What does your sensor look like? 4 pin? 2 pin?
If there is a single pin sensor with a green wire... that will be a direct connection to dash and has nothing to do with engine ecu.
Old Jun 15, 2017 | 03:34 PM
andytaxi's Avatar
1994 C200 w202
cheers for that haynes manual says the same but after speaking to an AA man on his tablet it showed it going to ecu. and yep single conector and green wire
Old Jun 16, 2017 | 04:01 AM
not a merc
No way! Single pin sensor with green wire goes via x26/25 next to abs pump at lf fender and into body harness straight to cluster. There will be another sensor with a green/red and a brown/white that goes to engine ecu.
Old Jun 16, 2017 | 03:12 PM
andytaxi's Avatar
1994 C200 w202
yep 2 sensors wires run into conduit to bottom of inlet manifold then go with what looks like tapped wires that come from the coil packs ,after removing washer bottle they all seam to end there, but didnt look passed there after paying for the ecu ££££s
Old Jun 18, 2017 | 08:04 AM
not a merc
Just ground the single pin green wire at the front of cyl head. With ign on the temp gauge should rise to max
Old Jun 18, 2017 | 01:19 PM
andytaxi's Avatar
1994 C200 w202
cheers for that, spent 3 hours this morn unwrapping the loom as far as the connector next the abs unit, which i thought may be the problem stripped cleaned and wd40, fitted all back and no result, so will try earthing the wire poss tomos as knakard in this heat
Old Jun 19, 2017 | 02:03 PM
andytaxi's Avatar
1994 C200 w202
hi russ tried that this evening and nothing happened, i take it that means a break in the wire
Old Aug 20, 2017 | 01:42 PM
andytaxi's Avatar
1994 C200 w202
sorted, i think temp gauge was not broke ,mot found brakes lights out, and found fuse had blowen changed fuse and temp sensor now works, it is also fuse for part of the dash pod, wich i persume contained the temp bit
Old Aug 23, 2017 | 11:00 AM
not a merc
Ok that's good
