will 19x9.5 fit and tuck in the rear???
95 c280
I was wondering if Brabus monoblock VI 19x9.5 will fit in the rear and if they will tuck if i slam the car out?
95 c280
so you have 8.5 and there looks like there is enough room to stuff a 9.5 up there?
1995 C36
hmm for me, it looks like any tire wider than 225 will rub the bumper and i dont believe you can fit 225's on 9.5's. you should ask other members how they do it because alot of ppl run wider tires in the back.
Uber 202
I have Brabus mono V 18 X 8.5 all around. Front 225/40 and rears 255/35. They fit fine. I had to roll the fenders slightly, no big deal. I had 19's before, I ran 225/35 front, and 245/35 rear. My buddy has a W202 also and ras 19" mono VI, 8.5 fronts 225/35/19 and 9.5 rear 265/30/19, He had to roll his fenders and cut the insides of the front and rear bumpers cut and shaved a little. About .5-1 inch need some trimming. His car is lowered. It can be done with a little work.
benzworld guy
I know there is a guy on my other forum, www.benzworld.org who has the 19x9.5 monblocks. He has no problem- think his name is BrabusNYC
http://www.benzworld.org/forums/view...=view&uid=8800
p.s.- why is ahoepter on probation???
1995 C36
yea im just running 225's all around but since you can fit wider tires with some mod i might consider getting 255's because right now they do look sorta small from the back.
me and sparcus are both running 245's in the rear on a 19x9.5. i have some pics available.
(taken off www.thewheelsupply.com)
95 c280
19in rims
ya today i ordered 19x8.5 and 19x9.5 brabus monoblocks VI and 225/35/19 in the front and 245/30/19 in the rear. it sounds like they should work and look pretty hot. if anyone has anymore pics of w202s on 19s hook me up. thanks
a car that can't do the throttle reset.
Re: will 19x9.5 fit and tuck in the rear???
Re: 19in rims
Originally posted by ShollyC220
WHY IS AHOEPTER ON PROBATION????
anyway, cause people dont like it when i tell them the truth, even if they already knew it.
Oh, well I was asking you, indirectly- so people compained and got you on probation then?
1 Post
2008 SLK-280
I deleated it because Henry's post was so far back.
Original post: I've said it before and I'll say it again...Henry has the baddest car on here!!!
I am referring to Henry's silver car with the 19s.
