How to remove ashtray flip down cover?
so i have the joy of going around S Curves to get to my work (its a joy to drive everyday) so me and my stock 1999 C230 Kompressor are having our lovely morning work drive when i hear my coins rattle, and in they go behind the actual flip down assembly area.
so i pop the ashtray out, and it was sorta hard to remove, took a REALLY hard push, then when i try to close it, it wont close or it will close but then 5 minutes later pop open.
now does anyone know how i can remove that WHOLE ashtray box area. i have the stock stereo with the 6 cd changer in the trunk, and i have that empty area under the stereo and above the ashtray flip down. i unscrewed the 2 screws there, and took out the compartment and i see that the ashtray unit just sits there, but even if i could take it out, is there a easier way where i can just take the door out and free the stuck change?
If you lift the area around the shifter (with the window switches), you can pull the cubbyhole up that is in front of the shifter. After you pull that up, there are two screws (that go in sideways, you need a short screwdriver). Removing those will release the ashtray.
Might I suggest you remove the ashtray and replace it with the ashtray-delete option. It's difficult to see in this picture, and ignore the COMAND and the moving of the climate control, but it replaces the whole ashtray and smaller cubbyhole with a large deep cubbyhole:
http://groups.msn.com/mbenznl/instal...o&PhotoID=2039
-s-
-s-
and i may look into getting that ashtray removed and putting in that large cubby hole thanks!
-s-
Thanks...
Thanks...
I will post a better picture when I find one.
-s-
1. take out the shifter wood piece that has the window swithces..just pull it up a little harder and it will come out.
2. When you do that, take out the gray plastic that sits below the ashtray.
just pull it up its not screwed to anything.
3. there will be 2 gold screws on bottom of ashtray on each side, take them out and pull the ash tray out...
Elvir
