Low cost ESM- Electronic Selector Module needed
Old May 15, 2020 | 11:07 AM
DavidNoble's Avatar
2000 C280
Red face Low cost ESM- Electronic Selector Module needed
Yes the title is an oxymoron when you are talking about Mercedes Benz parts, but I figured I would give it a try.
This is the vehicle that needs it:
2000 Mercedes C280 Sport Edition
VIN: WDBHA29G2YA847571
My existing module has an unclearable P1817-2 code so I am looking for a new or used module.
The current module part number is 202-267-054
The module Mercedes is selling to replace it is 202-267-08-24
The lowest cost I have found so far is $454.80 from MercedesPartsDelivered.com.
https://www.mercedespartsdelivered.c...ift-2022670824
If you have this part that you can part with for less please let me know.
Regards,
Old May 15, 2020 | 01:13 PM
DavidNoble's Avatar
2000 C280
Originally Posted by Plutoe
Get a second job!!
may have to work on first job first. Then I can get a second one
Old May 25, 2020 | 12:01 PM
DavidNoble's Avatar
2000 C280
ESM repair attempt
Going to try and repair first. Was a bugger to disassemble but found a few things that may have been wrong with it.
Old May 25, 2020 | 12:42 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
I assume you've checked your local pick n pulls?
Old May 25, 2020 | 12:44 PM
DavidNoble's Avatar
2000 C280
I searched junkyards online. Those who have it charge 90% of the new price I found.
Old May 25, 2020 | 01:31 PM
khomer2's Avatar
At a "pick and pull"?? no way.
Yes, possibly, if they've pulled the part out for you, but not at a pick n pull.
You have to do some "physical searching", if you want to keep your daughter's first born.
Old May 25, 2020 | 02:02 PM
DavidNoble's Avatar
2000 C280
Trouble shooting selector sensor.
This info was not available on WIS since the pot is not considered a servicable item. I reverse engineered it for anyone else dealing with this issue.
Better pic
Testing shown on pins 3 and 4 per my schematic not sure what actual pin numbers are
Old Aug 17, 2020 | 09:18 AM
DavidNoble's Avatar
2000 C280
SOLVED THIS CONDITION!
Apparently there is normal leakage current in the reverse lights that if you do not have your reverse lights installed, the P1817-2 will be set.
So you can read the voltage present with a multimeter as I did, but if you check it with a test light it will drain the voltage and drop the code.
Long story short. If you have a P1817-2 code in a w202 C280 chances are you have both reverse bulbs missing or blown.
I purchased new bulbs and the problem went away.
