Special Spark Plug Wrench?
Old Oct 12, 2004 | 04:58 PM
I,Zombie's Avatar
KOMPRESSOR
Twice now I have had a problem at about 1/2 a tank of fuel (93 oct), while accelerating from 75 to 85 passing...A stutter and then it runs rough for a few starts with the CEL on. Today I took the car to AutoZone where they diagnosed a "cyl 2 misfire" and recommended I get new plugs. I don't know if they have ever been changed, so I bought a new set of platinum plugs. I go to change the plug to only find out that my spark plug socket won't fit. Is there a special tool? My took kit was misssing some tools when I bought the car was that in there?
Old Oct 12, 2004 | 05:26 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
What year what engine? I use a regular spark plug socket on most of the Mercedes I work on. Make sure you are getting the basic plug required for your car. If a copper plug is called for, use that. If a platinum plug is required, don't go with +2 or +4. Make sure your plug wires are run properly after installing plugs.
-s-
Old Oct 12, 2004 | 05:34 PM
I,Zombie's Avatar
KOMPRESSOR
1999 C230 Kompressor, I just bought the Bosch platinum plugs that have the 4 electrodes on it... How would I determine which plugs my car is supposed to use?
Old Oct 12, 2004 | 05:56 PM
scorchie's Avatar
You can find the proper plug information in varying places on various models. Under the hood, in the owner's manual, at the dealership, etc.
I recommend against the plugs with the four electrodes on them (+4).
-s-
Old Oct 12, 2004 | 08:15 PM
I,Zombie's Avatar
KOMPRESSOR
-s-
Personal Preference or performance/ damage issues?
Old Oct 12, 2004 | 08:29 PM
scorchie's Avatar
Personal preference based on the experience of poor performance after installation of +4 plugs. Especially in both the I4 and I6 engines, as well as to a lesser extent in the M112/M113 engines.
-s-
Old Oct 12, 2004 | 10:53 PM
meanie's Avatar
Just go and get the proper plugs: Bosch F 7 KTCR !!!!
They have triple electrodes !
Old Oct 13, 2004 | 01:00 PM
I,Zombie's Avatar
KOMPRESSOR
-s-
Wow! you were quite right. On your recomendation I exchanged the plugs for the factory plugs (Bosch F 7 KTCR). I found out that a regular spark plug socket worked fine, and that I was using too big of a plug wrench . I pulled the old plugs which was a bosch platinum, toasted to a light brown. Replaced with what was recommended and zoom worked great! thanks
